Building a strobed 2048x1536@160Hz LCD
- rabidz7
Assuming that I can get a driver board capable of running the panel at 2048x1536@160Hz, how difficult would it be to install a strobe backlight? Is the response time on the NL204153AC21-25 even fast enough to allow strobing at 160Hz?
Rabidz7 is a: PowerPC Fan, LCD and x86 Hater, and a Plasma/OLED/CRT/SED/FED Lover
flood
spacediver
Re: Building a strobed 2048x1536@160Hz LCD
why are you so obsessed with refresh rate? There are so many other more important things about a display than its refresh.
- sharknice
Lol! strobe it at 25 fps40 ms
- rabidz7
I am aware that there is more to displays than refresh rate. I think a high-res, high-refresh rate 4:3 LCD would be an interesting idea.spacediver wrote:why are you so obsessed with refresh rate? There are so many other more important things about a display than its refresh.
