Where do I change the refresh rate?
Ahriman44
Post by Ahriman44 » 15 Aug 2015, 02:36
I have been using the strobelight app for a while now, but there was a large gap of time between when i started and now. It used to be that i could go into my hidden icons area, right click and choose from a drop down list what refresh rate i wanted (120hz, 110hz, or 100hz). After having installed the new app and refresh rates, it seems the only options i have are to turn strobing on or off. Where can i switch the different refresh rates?
masterotaku
Re: Where do I change the refresh rate?
Post by masterotaku » 15 Aug 2015, 03:11
That's something you do in the operating system. You can do it with the Nvidia Control Panel, AMD Catalyst Control Center and the monitor settings in Windows.
Monitor: Asus PG278QR
