I got X-Star DP2414LED several days ago just to overclock it and compare with my BenQ XL2411Z.
First of all I don’t like this strobed techs like LightBoost, ULMB, BenQ Blur Reduction and etc and I prefer to play fast twitched FPS. (Input lag is noticeable for me with strobe techs i tried LightBoost & BBR).
I’m also don’t need any Sync techs like FreeSync and G-SYNC. (FPS are 250 or more). Same with panel types. TN is enough for me.
No need to discuss this.
Someday I’ve found information about this monitors (QNIX QX2414LED & X-Star DP2414LED) at Blur Busters Forums and decided to try one of them. They are almost equal. The first one released was QNIX QX2414LED 144Hz 1.5ms with DVI-D only. The pros of DVI-D are may be less input lag and better chances to be overclocked. The next released was X-Star DP2414LED 144Hz 1ms with D-SUB/HDMI/DVI-D inputs and advertised ability to 185Hz overclock.
Overclocked to 185Hz and 200Hz. Got some scanlines at top right side of screen. At 200Hz monitor show white screen after 5-10-15 mins so I switched to advertised 185Hz. May be 185Hz because it’s stable.
What I can say for sure is that ghosting at 185Hz is much less than at 144Hz. Overdrive isn’t aggressive if exist
I’ve disassembled monitor to view at panel and scaler.
Panel is AUO M240HW01 V8. It’s same as in XL2411Z and in most of 24” 144Hz monitors.
Scaler (processor/main board) is different. May be it’s MST 2403 (MSTAR) - info from EDID.
Default 144Hz timings are:
"1920x1080" 328,890 1920 1968 2000 2080 1080 1084 1089 1098 +hsync +vsync
For XL2411Z timings are:
"1920x1080" 325,080 1920 1944 1976 2056 1080 1083 1088 1098 +hsync +vsync
At 200Hz horizontal scan rate (horizontal frequency) is ~220 kHz and pixel clock is 456 MHz.
EDID information:
Code: Select all
Monitor
Model name............... DVI
Manufacturer............. MST
Plug and Play ID......... MST2403
Serial number............ n/a
Manufacture date......... 2015, ISO week 22
Filter driver............ None
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 530 x 300 mm (24,0 in)
Power management......... Standby, Suspend, Active off/sleep
Extension blocs.......... None
DDC/CI................... Supported
MCCS revison............. 2.1
Display technology....... TFT
Controller............... Mstar
Firmware revision........ 1.0
Firmware flags........... 0x0000005A
Active power on time..... Not supported
Power consumption........ Not supported
Current frequency........ 220,30kHz, 200,60Hz
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2,20
Red chromaticity......... Rx 0,648 - Ry 0,339
Green chromaticity....... Gx 0,292 - Gy 0,603
Blue chromaticity........ Bx 0,143 - By 0,070
White point (default).... Wx 0,313 - Wy 0,329
Additional descriptors... None
Timing characteristics
Range limits............. Not available
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080p at 144Hz (16:9)
Modeline............... "1920x1080" 328,890 1920 1968 2000 2080 1080 1084 1089 1098 +hsync +vsync
Detailed timing #1....... 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148,500 1920 1968 2000 2200 1080 1084 1089 1125 +hsync +vsync
Detailed timing #2....... 1920x1080p at 100Hz (16:9)
Modeline............... "1920x1080" 247,500 1920 1968 2000 2200 1080 1084 1089 1125 +hsync +vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
640 x 480p at 75Hz - VESA
800 x 600p at 56Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 72Hz - VESA
800 x 600p at 75Hz - VESA
1024 x 768p at 60Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
800 x 600p at 100Hz - VESA STD
1024 x 768p at 100Hz - VESA STD
1280 x 1024p at 60Hz - VESA STD
1280 x 1024p at 100Hz - VESA STD
1600 x 900p at 60Hz - VESA STD
1600 x 900p at 100Hz - VESA STD
1680 x 1050p at 60Hz - VESA STD
1680 x 1050p at 100Hz - VESA STD
Report information
Date generated........... 23.09.2015
Software revision........ 2.90.0.1000
Data source.............. Real-time 0x0011
Operating system......... 6.2.9200.2
Raw data
00,FF,FF,FF,FF,FF,FF,00,36,74,03,24,00,00,00,00,16,19,01,03,80,35,1E,78,EA,3D,85,A6,56,4A,9A,24,
12,50,54,A7,CB,00,45,68,61,68,81,80,81,A8,A9,C0,A9,E8,B3,00,B3,28,79,80,80,A0,70,38,12,40,30,20,
45,00,55,50,21,00,00,1E,02,3A,80,18,71,38,2D,40,30,20,45,00,55,50,21,00,00,1E,AE,60,80,18,71,38,
2D,40,30,20,45,00,55,50,21,00,00,1E,00,00,00,FC,00,44,56,49,0A,20,20,20,20,20,20,20,20,20,00,8A
Some photos with packaging, frameskipping test, scanlines, disassembled monitor and etc http://imgur.com/a/Jo496
Not sure
Hard to say is it better or worse than BenQ XL2411Z. Need some more game sessions.
Shipping to Saint Petersburg, Russla from South Korea took 5 days. Well done EMS. Good packaging and speed.
item is http://www.ebay.com/itm/221822303311 and seller called dream-seller.
