BenQ XL2430T vs AOC G2460PQU
Tiago_177
Post by Tiago_177 » 15 Dec 2015, 18:12
Hi.
I'm currently undecided between the two monitors mentioned above, the BenQ XL2430T and the AOC G2460PQU/BR, where i'll be buying it from the AOC is around 90€ (100$) cheaper, personally i haven't had the chance to properly test both of them, so my question is which one is better and if the BenQ happens to be that one is it worth the extra, please try to explain why.
Thank you guys very much for your time, have a nice day ^^.
Jourgensen
Re: BenQ XL2430T vs AOC G2460PQU
Post by Jourgensen » 01 Jan 2016, 03:25
Both are crap, take the acer.
Maybe, if you really want to buy a crap panel with shitty colors, take the aoc because its cheaper.
Q83Ia7ta
Post by Q83Ia7ta » 01 Jan 2016, 09:32
I haven't tried AOC but had XL2411T, XL2411Z and Acer GN246HL. Last one is worst than BenQs with it's aggressive overdrive that can't be changed (no options at OSD at all). BenQ XL2430T cost more because it's BenQ. There are other BenQ models that cost less than XL2430T and don't have such fancy case and displayport. XL2411Z for example. In terms of picture quality, input lag and
capabilities they (XL2411Z & XL2430T) must perform same.
Also BenQ XL2430T (withou G-Sync) or AOC G2460PG (With G-Sync) https://forum.pcmonitors.info/topic/ben ... c-g2460pg/
lexlazootin
Post by lexlazootin » 01 Jan 2016, 13:38
There is nothing special about it, but the AOC isn't great either.
