i'm planning to play ps4 games using xl2411z at 120hz
i found a hardware that double the input frames :
http://www.aliexpress.com/item/2D-to-3D ... 6c74fe8d17
can be done ?
PS4 at 120hz & benq monitor
RLBURNSIDE
Re: PS4 at 120hz & benq monitor
If it uses frame interpolation to double the dps, it'll add latency or 1-2 extra frames at least. That's an extra 16-33 ms. BAD
If it doesn't use frame interpolation, that means it's just playing back the same input frame twice in a row, which is pointless and would look virtually the same.
Wait for a PS4K or Neo and then play games at actual 120fps, or buy a PC
when you get a serious eystrain from 60hz monitor and only 120hz refresh solve the problem tell me how you can play on a ps4 ?Q83Ia7ta wrote:rofl
your imagination is limited
- lexlazootin
Maybe it's the monitor causing eyestrain and not the 60hz.furtsiv wrote:when you get a serious eystrain from 60hz monitor
Yea, probably not. lolPS4K or Neo running 120hz
The product you listed is very vague on what it does and i wouldn't recommend you buy it. If you want 120hz buy a PC.
