Blur Busters Forums
BENQ XL2430T settings for CS:GO, regular use and movies
Postby cwirek91 » 14 Nov 2016, 14:15
In this topic I would like show the best settings for XL2430T, for CS:GO, movies and for regular use.
I use BENQ XL2430T (firmware v006-20151103) connected to a dual-link DVI port (GeForce GTX 1060).
CS:GO (1024x768)
Objective: the lowest lag input & good colors
- CS:GO settings:
Resolution: 1024x768 black bars
mat_monitorgamma 1.6
fps_max 0
- NVIDIA drivers settings:
Resolution: 1920x1080
Refresh rate: 120Hz
Scaling mode: Aspect ratio
nVidia Control Panel Desktop Brightness = 52%
nVidia Control Panel Desktop Contrast = 45%
nVidia Control Panel Desktop Gamma = 0.70
nVidia Control Panel Desktop Digital vibrance = 50%
nVidia Control Panel Desktop Hue = 0
VT Tweak: 1500
Custom Resolution:
- Monitor settings:
Blur Reduction: ON
Intensity: 1
Area: 49
Black eQualizer: 0
Color Vibrance: 18
Low Blue Light: 0
Instant Mode: ON
Auto Game Mode: OFF
Brightness: 100
Contrast: 50
Sharpness: 6
Gamma: Gamma 5
Color Temperature: User Define (R:99, G:100, B:99)
AMA: High
Display Mode: Full
Movies (1920x1080)
Objective: elimination blue light & good colors
Refresh rate: 120Hz
VT Tweak: 1500
Custom Resolution:
- Monitor settings:
Blur Reduction: ON
Intensity: 10
Area: 10
Black eQualizer: 0
Color Vibrance: 10
Low Blue Light: 10
Instant Mode: ON
Auto Game Mode: OFF
Brightness: 100
Contrast: 50
Sharpness: 6
Gamma: Gamma 3
Color Temperature: User Define (R:93, G:88, B:97)
AMA: High
Display Mode: Full
Regular use (1920x1080)
Objective: elimination blue light & good reading mode
Refresh rate: 120Hz
VT Tweak: 1500
Custom Resolution:
- Monitor settings:
Blur Reduction: ON
Intensity: 16
Area: 40
Black eQualizer: 0
Color Vibrance: 9
Low Blue Light: 10
Instant Mode: ON
Auto Game Mode: OFF
Brightness: 90
Contrast: 50
Sharpness: 6
Gamma: Gamma 5
Color Temperature: User Define (R:98, G:100, B:99)
AMA: High
Display Mode: Full
Do you have some propositions or improvements?
cwirek91
Re: BENQ XL2430T settings for CS:GO, regular use and movies
Postby Falkentyne » 14 Nov 2016, 18:40
VT 1500 is better than VT 1502 at 120hz. Sometimes the sync will fail (maybe 10% of the time) on a mode switch and you will get frame stuttering. This doesn't happen at VT 1500. VT 1502 is fine at 100hz.
Falkentyne
Postby Q83Ia7ta » 15 Nov 2016, 02:24
I just can't agree that blur reduction ON and 120Hz is better than blur reduction OFF and 144Hz for competitive FPS gaming.
I know it's personal but I'm sure most players prefer BBR off for competitive FPS gaming.
Q83Ia7ta
Postby cwirek91 » 15 Nov 2016, 03:15
Falkentyne wrote:VT 1500 is better than VT 1502 at 120hz. Sometimes the sync will fail (maybe 10% of the time) on a mode switch and you will get frame stuttering. This doesn't happen at VT 1500. VT 1502 is fine at 100hz.
I will try on 1500.
Q83Ia7ta wrote:I just can't agree that blur reduction ON and 120Hz is better than blur reduction OFF and 144Hz for competitive FPS gaming.
cwirek91
Postby Q83Ia7ta » 15 Nov 2016, 04:47
cwirek91 wrote:*some image I saw a years ago*
Thank you. I know what are strobing techs for monitors for years.
Q83Ia7ta
Postby lexlazootin » 15 Nov 2016, 08:40
Proceeds to adjust brightness, contrast, gamma and digital vibrance.
I will never understand this. Good colour is only one thing, accurate colour. Pointlessly adjusting random nobs to makes stuff look better is just stupid. Some people put a lot of time into adjusting things to be viewed a certain way and this is a spit in the face to them. This also has a side effect of lowering the dynamic range as you're cramming everything into a small 8bit envelope.
> fps_max 0
From what I've been told, you want to lower your max fps to just below the value it drops to to reduce latency. I can't remember why, but someone smarter then me can maybe explain it.
lexlazootin
Postby cwirek91 » 17 Nov 2016, 08:35
lexlazootin wrote:> Objective: the lowest lag input & good colors
If you have better settings colours you can easier see the enemies. That's should help also in see enemies in a smoke. It's very hard to set right settings for own eyes. Accurate colours it's very important in regular use / movies mode.
lexlazootin wrote:> fps_max 0
I have heard its better have unstable 200/300+ fps instead constant 120 (fps_max 121). Your movement also its better than on 120 fps. I tested it and it seems like that. On constant 120 fps I'm a bit slowly - I think so.
cwirek91
Postby cwirek91 » 21 Nov 2016, 09:06
I tried VT1500 and it's really better than 1502, how you said. Do you have some other improvements? Like colour settings or something?
cwirek91
Postby cwirek91 » 05 Dec 2016, 09:51
Where can I set something like LightBoost 10% vs 50% vs 100% in BENQ 2430T? Like this on Asus: Image
cwirek91
Postby lexlazootin » 05 Dec 2016, 11:00
You can adjust the BBR in the monitors service menu or with the BlurBuster's Blur Busting Buster®©™ app!
http://www.blurbusters.com/benq/strobe- ... ce=sidebar
Sadly i don't believe your specific monitor is supported so to enter the service menu you want to hold down the "Menu" button while turning on your monitor, and then once on press menu again.
You can change a bunch of cool settings and adjust BBR to your desire!
lexlazootin
Next
Who is online
Users browsing this forum: No registered users and 3 guests
