Im connected via DisplayPort, I downloaded CRU from the website, added (under DETAILED RESOLUTION), set the timing to Automatic LCD Standard as mentioned in the guide, and tried to set the vt to around 1570 @ 180hz, but the pixel clock already exceeded 600mhz (it reached a bit over 640)
after I tried enabling the resolution with 1450VT (which showed to be below the pixel limit .. it was like 591) it became like squared and VERY badly scaled..
what am I doing wrong? the crosstalk is awful really... I need your help fellas
![Sad :(](./images/smilies/icon_e_sad.gif)
tried adding custom resolutions via Nvidia Control Panel, same results..
Im just doing something wrong I guess
