Blur Busters Forums
List of upcoming freesync monitors
Re: List of upcoming freesync monitors
Postby GitDat » 11 Jun 2017, 08:16
That CHG90 has me drooling :shock: The back doesn't look VESA compatible but the chart states wall mount support. I hope the strobing mode is adjustable for brightness :)
NZXT H700i | MSI Meg Z390 Godlike | NZXT Kraken X72 | 9900K | 32GB TridentZ RGB 3600MHz | RTX 2080 Ti | Samsung 960 Pro NVMe M.2 SSD RAID-0 | Corsair AX860 | 3DMark Port Royal - 9512 | Samsung CHG90 Super-Ultrawide | Samsung CHG70 Auxiliary
GitDat
Postby whitestar » 13 Jun 2017, 02:51
I noted these words in the marketing text: "The CHG90 also boasts a rapid 1ms response time, 144hz screen refresh rate, and advanced, four-channel scanning technology to deter motion blur throughout the entire screen".
What does that in bold mean?
Also, I'm wondering about the following:
1. How tall is it? Same height as a 27"?
2. Can the Hz be set in 1Hz steps, or are there only "set" Hz settings, i.e. 60, 75, 85, 100, 120, 144? That is, when not using Freesync obviously (I have an nVidia 1080 Ti).
whitestar
Postby RealNC » 13 Jun 2017, 03:25
whitestar wrote:1. How tall is it? Same height as a 27"?
It's about the same height as a 27" 16:9. The height of a 49" 32:9 is 13.3". The height of a 27" 16:9 is 13.2". So basically it's the same, except with more space on each side.
I don't know if the curvature plays into it though. The height might be wrong depending on how they measure the diagonal (straight or curved diagonal.)
Postby Chief Blur Buster » 15 Jun 2017, 12:27
whitestar wrote:2. Can the Hz be set in 1Hz steps, or are there only "set" Hz settings, i.e. 60, 75, 85, 100, 120, 144? That is, when not using Freesync obviously (I have an nVidia 1080 Ti).
This is Samsung proprietary blur reduction capability -- someone will have to test strobing with custom refresh rates to see if it works.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
Previous
Return to FreeSync
Who is online
Users browsing this forum: Google [Bot] and 0 guests
