Questions about new G-Sync monitor
parini
Post by parini » 30 Jun 2017, 19:34
Maximum pre rendered frames 1 + Gsync+Vsync(nvcp) Stop stturterign?
Post by jorimt » 30 Jun 2017, 19:53
parini, I ask again, what game are you getting stutter with? As for Maximum pre-rendered frames at "1," it won't always fix stutter.
G-SYNC can only fix so much.
parini
Post by parini » 30 Jun 2017, 22:00
Games: Battlefield 3, League of legends, Call of duty black ops 3,
I bought gsync thinking it ended up stturtering: /, what setting do I play without stturterign and let my normal gameplay?
parini
Post by parini » 30 Jun 2017, 22:21
https://linustechtips.com/main/topic/39 ... very-game/
I did it my stutter stopped, what will these commands do?
Post by jorimt » 30 Jun 2017, 23:14
parini, now we are getting off the subject. Those settings have nothing to do with G-SYNC.
Try disabling G-SYNC and V-SYNC. Do you still see the stutter with V-SYNC and G-SYNC completely off? If you do, then it means G-SYNC isn't causing the stutter. G-SYNC can't cause stutter.
G-SYNC ONLY fixes V-SYNC stutter. It can NOT fix other causes of stutter.
parini
Post by parini » 30 Jun 2017, 23:22
I'm using the correct one that you informed me about gynyn on vsync on nvdia panel and fps limited to 162 even I feel feel stuttering while the fps fades down, plus I did that command and stopped the stutters
parini
Post by parini » 30 Jun 2017, 23:23
cmd: bcdedit /set disabledynamictick yes Stop stturtering.
Post by jorimt » 30 Jun 2017, 23:33
That is a CPU setting parini, it is not related to G-SYNC. I'm glad it seemed to fix your stutter though.
parini
Post by parini » 30 Jun 2017, 23:34
This command in some games looks horrible: /
parini
Post by parini » 30 Jun 2017, 23:38
League of legends when the fps drops sharply from the one caught on the screen a very large stturtering, from 162fps dropped to 140 gave a lock on the screen.
