Questions about new G-Sync monitor
parini
Re: Questions about new G-Sync monitor
This happens when you stay away from the gsync range with gsync on.
parini
What does this technology monitor fixed refresh rate
- jorimt
Does it happen on loading screens with G-SYNC and V-SYNC off?
parini
Not only happens with gsync.
- jorimt
Alright, so the only problem you are having with G-SYNC, is that the screen flickers (like an old film or movie), and only on loading screens?
I'm having a hard time understanding what you mean by "starts to shine like a star." Again, it would help to see it, but you say it is mild enough that you can't capture it with your camera.
Does it bother you that much?
parini
Just happens when loading some game with gsync with high frametime, you once told me that it is normal to happen with panel tn
- jorimt
If that is your only problem with G-SYNC parini, where it looks like it is flickering like an old film on loading screen only, as I told you before, that is normal for G-SYNC and some TN panels at very low framerates.
Again, nothing to worry about.
parini
I was able to take the blessed sturttering after killing me so much I would only leave the fps unlocked, Gsync On + Nvidia Panel Vsync On + Fps unlocked.
parini
Is it good to use this way the sturttering is finally over? Does this setting have inputlag?
- RealNC
Yes. Unlocked FPS has input lag.
How were you locking the FPS before? With what software?
