Questions about new G-Sync monitor
parini
Re: Questions about new G-Sync monitor
Post by parini » 01 Jul 2017, 22:44
Was unlocking for rtss and game
Post by jorimt » 01 Jul 2017, 23:21
parini, are you using only RTSS or the in-game FPS limiter to limit to 162 FPS?
Don't use both at the same time. Use only one.
Also, are you sure you are at 165Hz? Can you embed a screenshot of this to confirm:
Displays: ASUS PG27AQN, LG 48C4 OS: Windows 11 Pro Case: Fractal Design Torrent PSU: Seasonic PRIME TX-1000 MB: ASUS Z790 Hero CPU: Intel i9-13900k w/Noctua NH-U12A GPU: GIGABYTE RTX 4090 GAMING OC RAM: 32GB G.SKILL Trident Z5 DDR5 6400MHz CL32 SSDs: 2TB WD_BLACK SN850 (OS), 4TB WD_BLACK SN850X (Games) Keyboard: Wooting 60HE v2 Mouse: Logitech G Pro X2 SUPERSTRIKE Sound: Creative Sound Blaster Katana V2 VR: Beyond 2, Quest 3, Reverb G2, Index Consoles: N64, Analogue 3D, Dreamcast, PS2, PS3, PS5 Pro, Switch 2, Wii, Xbox, Xbox 360, Analogue Pocket + Dock Scaler: RetroTINK 4k
parini
Post by parini » 02 Jul 2017, 01:12
Post by RealNC » 02 Jul 2017, 02:42
If the stutter issue is specific to League, this might be relevant:
https://support.riotgames.com/hc/en-us/ ... gh-End-PCs
This seems to be a VERY new issue (only 3 days old.)
Post by jorimt » 02 Jul 2017, 09:18
parini, you are definitely at 165Hz, thanks for the image.
If you are using G-SYNC + V-SYNC + 162 FPS limit with RTSS or in-game limiter (again, don't use both, use only one), the only way you can be getting stutter, is if the game is causing it.
Have you tried turning G-SYNC and V-SYNC off, and seeing if the games are still stuttering? If they are, G-SYNC can't fix that stutter.
parini
Post by parini » 02 Jul 2017, 11:31
I'm using the rtss to limit it, the funny one when the fps gets unlocked to stutter some.
parini
Post by parini » 02 Jul 2017, 12:21
I'm playing gta as I walk in the car on top of a light shines more than the others on the monitor is this normal?
Post by jorimt » 02 Jul 2017, 12:37
Without a better description, I have no idea what you are talking about. Can you take a picture with your camera for me to see?
parini
Post by parini » 02 Jul 2017, 12:56
I just filmed
