I don't know the technical aspects of this, but I'll input what I can.
I tried that utility with my Yamakasi Catleap, and it gave me the error "No supported displays found". Messing around with it a bit, I had the same message, ever time. This leads me to believe, plus what I've read up on that thread, because there is no OSD, or maybe not alto of internal controls or electronics, may be one reason these Korean brands may not work. Just my guess.
Of course you have f.lux, but that just matches the luminescence of the room, and doesn't really make it brighter or dimmer, and probably not quite what you need. It does have a feature to turn colors beyond the range they give you upon first install, but again, I believe it to not quite be what you need.
I've found a few other results that were easily-written programs using some version of .Net, but these are pretty similar in that they will darken the main desktop and windows, but menus when you right click, or the taskbar all the time, and mouse cursor are not dim. But still, the best solution I was able to find in a limited amount of time.
This is my favorite one here:
http://download.cnet.com/Monitor-Bright ... 90260.html
This one here did not do anything for me whatsoever, but I believe that to be an OS incompatibility for my 8.1 install
http://www.nelsonpires.com/software/dimmer/
