xl2540 vs other 144hz
krypton111
Post by krypton111 » 20 Sep 2017, 06:46
Hello to all
I wanted to know if the new benq xl 2540 240 hz has less input lag than other 144 hz or 2411z 144hz best? ?
i play cs go all the time and i want less input lag possible
thanks to everyone for the answers
Q83Ia7ta
Re: xl2540 vs other 144hz
Post by Q83Ia7ta » 20 Sep 2017, 08:36
yes
krypton111
Post by krypton111 » 20 Sep 2017, 09:27
Q83Ia7ta wrote:yes
yes what?
lexlazootin
Post by lexlazootin » 20 Sep 2017, 09:43
More HZ = Less latency.
It's only by a tiny amount but yea.
krypton111
Post by krypton111 » 20 Sep 2017, 12:02
lexlazootin wrote:More HZ = Less latency.
less latency of 2411z or 2530 more tatency?..........
lexlazootin
Post by lexlazootin » 20 Sep 2017, 13:50
240hz has less latency then the 144hz
Post by Chief Blur Buster » 20 Sep 2017, 14:29
lexlazootin wrote:240hz has less latency then the 144hz
Correct.
As a rule of thumb:
- More framerate, same Hz = less lag
- Same framerate, more Hz = less lag
- Doing both = even less lag
Which is to say for higher Hz, same frame rate situations:
- 100fps at 240Hz = less latency than 100fps at 144Hz
- 300fps at 240Hz = less latnecy than 300fps at 144Hz
And higher frame rate, same Hz situations:
- 300fps at 144Hz = less latency than 100fps at 144Hz
- 300fps at 240Hz = less latency than 100fps at 240Hz
This generally applies to all real-time scanout TN LCD monitors, which most eSports displays are -- including the BenQ/Zowie XL series.
This is something we noticded on the side, in VSYNC OFF modes (non-GSYNC) during our GSYNC 101 lag tests on a 240Hz monitor (later sections, "Beyond the Scanout").
krypton111
Post by krypton111 » 20 Sep 2017, 14:48
Correct.
As a rule of thumb:
yes but I had read around that the 2450 had more input than 144 hz lags
Post by Chief Blur Buster » 21 Sep 2017, 13:23
krypton111 wrote: yes but I had read around that the 2450 had more input than 144 hz lags
Where did you hear that? Zowie/BenQ monitors have generally been extremely low lag, supporting real-time scanout.
If you're talking about XZ2546 strobing, remember that DyAc can also be turned off via service menu or Blur Busters Strobe Utility.
Straifer
Post by Straifer » 26 Sep 2017, 03:56
some additional info for this topic -
I have a 2720z and a XL2540 and to keep it simple. All testing for me is Overwatch 300 fps, no blur reduction just purely trying to get the best input 'feel'
2720z DVI-D - feels great but the refresh difference is noticeable after some months of owning the XL2540
2720z Displayport - feels worse
XL2540 DVI-D 'Overclocked' to 240hz felt great BUT it no longer displays this resolution in Overwatch without using CRU ( Previously using Nvidia control panel to OC.) I'm fairly new to CRU so I'm still not sure if you can make CRU change Desktop Refresh rate aswell as game Refresh.
XL2540 Displayport - Would rather be using DVI-D but the gain in image smoothness is really noticeable over 144hz.
I myself am quite curious is there is a true latency difference between DVI-D and displayport, everything that I've read has told me it would be placebo effect. Maybe there is something in frame time lows? Basically it's beyond me but I do feel there is a difference.
