[Bug?] Drivers forgetting I have a G-sync display
- nimbulan
The first time I thought it was a fluke but it just happened again. I started a game, noticed some stuttering and tearing so I check the monitor OSD and G-sync is not enabled. In the control panel the vsync behavior has been changed back to default and G-sync is no longer an option, like I don't have a G-sync display attached. I have to reboot to fix it. Has anyone else experienced this?
- ManuelG_NVIDIA
Re: [Bug?] Drivers forgetting I have a G-sync display
Have you tried reinstalling the driver with clean install? Can you give me your system specs to see if we can reproduce here?
Please send me a PM if I fail to keep up on replying in any specific thread.
- nimbulan
I actually already sent you system information to check into the tearline problem I've been having. Here are the links again: DXdiag, nVidia System InfoManuelG_NVIDIA wrote:Have you tried reinstalling the driver with clean install? Can you give me your system specs to see if we can reproduce here?
Windows 7 64 bit
Intel Core i5-4670k @4GHz
GTX 760
8 GB RAM
I'll try a clean install with the new beta driver but it may be a while before I can confirm if that fixed anything or not since it has only happened twice in about a month.
(Idea: Maybe re-run DXdiag and nVidia System Information again the next time you see this happens?)
- nimbulan
It just happened again. I noticed that G-sync wasn't functioning while playing a game and G-sync is not available in the control panel. This is the first game I've launched today, but I believe G-sync was functioning was a video player earlier in the day. Here are the new DXdiag and nVidia System Info
- nimbulan
Quick update: I left my computer on overnight with the monitors turned off. Today, G-sync is working again. I'm pretty sure I tried power cycling the monitor the first time this happened so I'm not sure what to think at this point.
PiERiT
This has happened to me as well. It happened once a couple weeks ago and I didn't think much of it, but it's happened twice so far today.
- nimbulan
I'm up to 4 or 5 times now? At least that I've noticed.PiERiT wrote:This has happened to me as well. It happened once a couple weeks ago and I didn't think much of it, but it's happened twice so far today.
PiERiT
I'm running a different OS and card than you, so I don't think the problem is with those. Might be the drivers?nimbulan wrote:I'm up to 4 or 5 times now? At least that I've noticed.PiERiT wrote:This has happened to me as well. It happened once a couple weeks ago and I didn't think much of it, but it's happened twice so far today.
Windows 8 x64
GTX 780
334.67
annisman
Just thought I'd add my name to the list too. This happened to me a few minutes ago. I was playing a game for an hour or so, when I noticed my display flicker or change colors or something, it was something that made me stop for a split second. So I hit my OSD and it said 'normal' mode instead of 'gsync'.
I then went to the Nvidia Control Panel and like magic, the option for use Gsync was gone, so was the set up Gsync tab. A reboot brought everything back to normal. Any idea on what this is guys ?
My driver is 334.89 and I've had it installed for a few weeks now no problems.
Specs: GTX Titan, 3930K, 16GB Ram, 650ti set as Phsyx
