Adjusting BENQ Blur Reduction and DyAc (Dynamic Acceleration) including
Blur Busters Strobe Utility. Supports most BenQ/Zowie Z-Series monitors (XL2411, XL2420, XL2720, XL2735, XL2540, XL2546)
bearbeardbeer
Post
by bearbeardbeer » 04 Dec 2017, 15:50
Hello guys! Im from Turkey, so my English not so good. Please be patient when listen to me. I bought this monitör 2 months ago and I did these settings:
- On monitor Blur Reduction "On"
- Use blur reduction utility
- In invida create new resolution and 1350 trick 120 hz.
- Persistance is 1.5ms
so i want to ask is it enough to play online game smoothly? Should i do anything more? And my other question; i dont know which is better 144hz or 120 hz with strobe and 1350 trick?
last question is: what can i do for more smooth resolution? i read some articles for 75 hz more smooth is it true? pls help me
bearbeardbeer
Post
by bearbeardbeer » 04 Dec 2017, 16:09
I read some articles and im going to change vertical to 1500 and it is more good than 1350. now what can i do more good things?
Post
by Chief Blur Buster » 04 Dec 2017, 22:32
VT1500 only works on some monitors. VT1350 is used for older BenQ monitors because they can't do VT1500 at 1080p.
-- Yes, the bigger VT the better for crosstalk
-- No, not all monitor models can support VT1500.
At some point, your picture blanks out when the monitor signal is beyond the capabilities of the monitor.
bearbeardbeer
Post
by bearbeardbeer » 05 Dec 2017, 03:56
Chief Blur Buster wrote:VT1500 only works on some monitors. VT1350 is used for older BenQ monitors because they can't do VT1500 at 1080p.
Please can u answer my other questions? what should i do for more smoothly monitor? My settings is enpugh or can i do more things? if i do more things can u explain what can i do
