Ask about
motion blur reduction in gaming monitors. Includes ULMB (Ultra Low Motion Blur), NVIDIA LightBoost, ASUS ELMB, BenQ/Zowie DyAc, ToastyX, black frame insertion (BFI), and now framerate-based motion blur reduction (framegen / LSS / etc).
enterprise24
Post
by enterprise24 » 28 Nov 2017, 06:15
RealNC wrote:enterprise24 wrote:Hi I just try ULMB+G-Sync on my S2716DG. Try +1 and +5 VT both are success. But I want to know how to force it to work on fullscreen mode. Currently need to play on borderless or forced via borderless gaming app.
Does this monitor do ULMB at 144Hz? If not, then in the NVCP, in the 3D settings section, set "preferred refresh rate" to application controlled. Otherwise, starting games will switch the monitor to 144Hz.
Thanks !! Full screen working wonderfully now.
After trying fullscreen lag / stuttering disappear. The questions remain what is proper settings for ULMB + G-Sync.
Calolo
Post
by Calolo » 14 Dec 2017, 02:43
Hi,
I own a ViewSonic XG2703-GS monitor and I try to enable G-Sync+ULMB.
I followed the steps with CRU, adding +5 (1525->1530) in the 120Hz profile.
After restart, when I switch to the modded 120Hz settings the "ULMB" option is greyed in the screen OSD.
If I reset CRU modifications and restart the driver, I can enable ULMB through OSD @120Hz, but not G-Sync.
I have a fresh Windows 10 and the lastest Nvidia drivers.
Thanks for yoour help!
Post
by RealNC » 14 Dec 2017, 04:32
Have you followed the steps as described here:
viewtopic.php?f=4&t=2883&start=180#p25654
Steam •
GitHub •
Stack Overflow
Calolo
Post
by Calolo » 14 Dec 2017, 05:46
Yes I followed these instructions.
My monitor is greying the ULMB option when using the custom 120Hz profile, maybe the firmware has been patched in the last revision ?
Post
by Chief Blur Buster » 14 Dec 2017, 13:00
Have you tried the change via ToastyX CRU instead of NVIDIA CRU?
Calolo
Post
by Calolo » 16 Dec 2017, 19:43
I used ToastyX CRU. Do you think Nvidia CRU would work better?
enterprise24
Post
by enterprise24 » 17 Dec 2017, 09:35
If I use G-Sync + ULMB at 120Hz should I limit my frame to 118 (2 fps below refresh rate ) or 119.XXX (with low lag v-sync method) ?
lexlazootin
Post
by lexlazootin » 17 Dec 2017, 10:56
2 below the refresh rate.
The 119.xxx makes sense if you DON'T have G-sync since but it has more latency.
enterprise24
Post
by enterprise24 » 18 Dec 2017, 04:24
lexlazootin wrote:2 below the refresh rate.
Thanks. I use 119.XXX since reading this thread not too long ago. Will try 118 now. So the optimal settings is.
G-Sync On
ULMB On
V-Sync On
RTSS limit = 118
Post
by RealNC » 18 Dec 2017, 11:09
enterprise24 wrote:Thanks. I use 119.XXX since reading this thread not too long ago. Will try 118 now. So the optimal settings is.
G-Sync On
ULMB On
V-Sync On
RTSS limit = 118
https://www.blurbusters.com/gsync/gsync ... -settings/
Steam •
GitHub •
Stack Overflow
