Blur Busters Forums
Nvidia Introduces 65-inch "Big Format Gaming Displays"
Re: Nvidia Introduces 65-inch "Big Format Gaming Displays"
Postby dhaine » 10 Jan 2018, 21:27
they need some antiblur tech, that works even on console, with low input lag, to be of interest
dhaine
Postby Manimal 5000 » 11 Jan 2018, 02:06
I don't let the size thing bother me. There are solutions that don't involve a couch. This setup has been working well the past few years...a wireless mouse wil complete the picture. Can't wait to see what Chief reports.
Manimal 5000
Postby darzo » 11 Jan 2018, 03:28
You need the adapter or whatever it is for a wireless mouse close to the mouse for good performance. I know this from experience. Logitech even goes as far as to recommend within 20 centimeters, which is ridiculous but says something. You've got D.Va on that monitor but from a competitive standpoint you probably will do better with other monitors, but I realize it might be a compromise. I expect that the 27-inch 144hz 4k monitor will be worse than a 1080 240hz monitor, which I may end up testing.
darzo
Postby lexlazootin » 11 Jan 2018, 06:37
Nice mouse ;)
lexlazootin
Postby Manimal 5000 » 11 Jan 2018, 11:04
lexlazootin wrote:Nice mouse ;)
Yes, if only they were wireless back then :mrgreen:
Manimal 5000
Postby Manimal 5000 » 11 Jan 2018, 11:37
darzo wrote:You need the adapter or whatever it is for a wireless mouse close to the mouse for good performance. I know this from experience. Logitech even goes as far as to recommend within 20 centimeters, which is ridiculous but says something. You've got D.Va on that monitor but from a competitive standpoint you probably will do better with other monitors, but I realize it might be a compromise. I expect that the 27-inch 144hz 4k monitor will be worse than a 1080 240hz monitor, which I may end up testing.
20cm really? You might as well stay wired. That wouldn't work at all.
I do hope they reconsider 4K on these monitors for ppl who like ULMB @ 100-120fps.
Manimal 5000
Postby Chief Blur Buster » 11 Jan 2018, 15:16
Distance also depends on a variety of factors including radio frequency interference. A house in the country would have better mouse performance at 50cm than a New York apartment at 20cm, due to the huge amounts of wireless signals sharing the space.
Also, you can use a USB extension cable (no repeaters though! So only up to 5 meter) to wire the wireless mouse receiver much closer to your seating area. That won't add lag, and allow you to keep very near your wireless mouse receiver.
Meanwhile, check out www.blurbusters.com for my personal impressions of:
-- HTC VIVE versus VIVE PRO greatly improved virtual reality
-- ROG 144Hz gaming laptop (brief impression)
-- ASUS BFGD
-- RAZER Phone with 120Hz display
More to come...
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
Postby darzo » 11 Jan 2018, 16:49
https://www.pcgamesn.com/nvidia-gsync-hdr-release-date
Any reason to go ultrawide at 1440 vs 4k at 27 inches?
darzo
Postby Manimal 5000 » 11 Jan 2018, 19:40
Chief Blur Buster wrote:you can use a USB extension cable (no repeaters though! So only up to 5 meter)..That won't add lag, and allow you to keep very near your wireless mouse receiver.
I was wondering about that. If you say it I believe it. Well looks like no ULMB at the moment doesn't it, meh.
Manimal 5000
Postby Mr.Fruitbaskets » 13 Jan 2018, 07:12
I don't get it, whats better about the bigger screen size? More ideal for people using surround sound setups, bringing people in the room to watch your banging setup?
Mr.Fruitbaskets
PreviousNext
Return to News / Rumors / Conventions
Who is online
Users browsing this forum: No registered users and 1 guest
