Aeon wrote:Chief Blur Buster wrote:if GSYNC 120fps@120Hz looks worse than normal 120fps@120Hz
just tested it in cs:go. 120fps@120hz with or without g-sync looks 100% identical, no artifacts at all.
Well, thanks you all for answers. I think I can live with that without problem. <60fps is a shitty experience anyway
Ok, we ruled out a certain type of inversion defect, then!
If you see no inversion artifact difference between GSYNC and non-GSYNC at stable and high frame rates.
So, it appears that it is simply the varying of your refresh rate that's amplifying inversion artifacts.
This is a common problem on many VRR monitors, especially of the TN type.
That said, some TN panels do a much better job, so if you buy a different TN GSYNC monitor, you might (or might not) have far less inversion artifacts during variable situations.
If you want a monitor that doesn't have VRR-induced visibility of inversion artifacts, you may want to consider an IPS GSYNC monitor. There are pros/cons if you go this approach (Slower pixel response) but it's an option if you're heavily annoyed by inversion artifacts.
