Presenting the ZOWIE XL2540 240Hz
ecay
Re: Presenting the ZOWIE XL2540 240Hz
Post by ecay » 19 Feb 2018, 15:52
Hi guys. I cant find how to access XL2540 service menu and activate blur reduction. Please help me thank you.
Post by Chief Blur Buster » 19 Feb 2018, 16:33
ecay wrote:Hi guys. I cant find how to access XL2540 service menu and activate blur reduction. Please help me thank you.
The factory menu instructions are here.
The instructions work for the following monitors:
BenQ ZOWIE XL2540 - 24.5" 1920x1080 TN 240Hz FreeSync
BenQ ZOWIE XL2546 - 24.5" 1920x1080 TN 240Hz FreeSync
BenQ ZOWIE XL2720 - 27" 1920x1080 TN 144Hz
BenQ XL2730Z - 27" 2560x1440 TN 144Hz FreeSync
BenQ ZOWIE XL2735 - 27" 2560x1440 TN 144Hz
BenQ XL2420Z - 24" 1920x1080 TN 144Hz
BenQ ZOWIE XL2411 - 24" 1920x1080 TN 144Hz
BenQ ZOWIE XL2430 - 24" 1920x1080 TN 144Hz
BenQ XL2720T - 27" 1920x1080 TN 120Hz
ecay
Post by ecay » 25 Feb 2018, 08:11
Thank you. I find the menu but there is no blur reduction option.There may be not some monitors may be.
Falkentyne
Post by Falkentyne » 25 Feb 2018, 12:48
Ecay,
the blur reduction setting is in the SERVICE MENU. The service menu is: Power off, hold button #4 for 5 seconds, power on while holding button #4, then release.
Then press button 4 to enter the service menu.
The factory menu is buttons #3 and #4 held down. and then button #5 to enter.
razu1102xd
Post by razu1102xd » 04 Mar 2018, 23:51
hello
I bought this monitor yesterday.
and i heard xl2540 has dyac mode(mbr).
is XL2546's Dyac and XL2540' mbr is completely same thing ?or is there difference ?
sry for bad english
Post by Chief Blur Buster » 05 Mar 2018, 02:03
razu1102xd wrote:is XL2546's Dyac and XL2540' mbr is completely same thing ?or is there difference ?
They are very close but not identical....
Generally speaking:
BenQ/Zowie DyAc -- official strobe mode enabled via main menus, usually is brighter (with voltage-boosting electronics).
BenQ/Zowie Blur Reduction -- unofficial strobe mode enabled by Service Menu. Not as bright.
Brutek_Vladimir
Post by Brutek_Vladimir » 06 Sep 2018, 12:06
At
https://www.benq.com/en-au/support/down ... river.html
I fould this:
XL2540 RTD ISPTool
Is it possible we can upgrade XL2540 firmware now?
Or some benq employee just screw things?
