Alienware AW2518H connected to the PC.
You guessed wrong, that driver version doesn't exist...could u check it maybe?giubox360 wrote:driver version 391,09 I guess.
No, I stick with VT 1304.giubox360 wrote: It seems similar to the LG monitor, but maybe a "street view" test could help more.
One thing I don't understand is that VT1304 doesn't seems to improve the MBR, maybe just a bit the Blacks.
I followed your tutorial with ToastyX, after restarting the PC the digital brightnees was resetted in the Nvida panel so I guess it worked.
Do you find a real better MBR with the VT 1304?
Thats a benchmark (first in google): https://www.humanbenchmark.com/tests/reactiontime/A Solid lad wrote:You two are really fast... I could only manage around 190 if I tried really hard, lol.
Are u using the same test as me? (https://faculty.washington.edu/chudler/ ... green.html)
btw, I've realised as well, that drivers play a huge part in dpc latency... I was about to install the latest drivers after uninstalling the previous ones with DDU (thought I'd give fresh gpu drivers a try) AND BOOM 4-6 microseconds of latency in dpc latency checker...
so guess I'll have to reinstall drivers until I find one with low dpc overhead...
yeah sorry you are right: my driver version is 391,01A Solid lad wrote:You guessed wrong, that driver version doesn't exist...could u check it maybe?giubox360 wrote:driver version 391,09 I guess.
It's strange every driver works differently with a different monitor, so let us know what is the best driver for you. (your actual driver is? )A Solid lad wrote:Hmmm... do I have to upgrade my gfx card, just to get lower dpclat? gah...
I'm now in the process of trying out different drivers, doing a DDU uninstall before every install.
I've your installed, and I get dpclat that is fluctuating between 13-22-32...jumping from one nimber tonthe other... horrible, compared to my older drivers.
I've sold my Benq 1 hour ago... a guy came for it himself. (150 eur...couldn't ask more, since the xl2411 can be bought new for around 240...)
So testing with that, won'r be possible... but I might test with the Dell and LG.
