The standalone DIY G-Sync board available?
JakeNQuake
I know some retailers are selling pre-modded VG248QEs, but I already have this LCD, so I want the module itself. Anyone know when/where/how much the standalone board will be? Will it be on Amazon? Will it actually be $100?
Re: The standalone DIY G-Sync board available?
They've updated their webpage today, to mention sometime in January, according to NVIDIA:
Taken from NVIDIA's G-SYNC page.NVIDIA wrote:(Update December 20, 2013: We are excited to confirm that the NVIDIA G-SYNC Do-It-Yourself Kits will be available for purchase in early January. Further details will be announced shortly.)
Is it coming for the Asus VG278HE?
If not, when can we expect a pre-installed G-Sync with a 27" monitor?
I'm told later in 2014.crun wrote:Is it coming for the Asus VG278HE?
No models currently announced yet, though.
You mean G-Sync DIY board, compatible with VG278HE, is coming later this year, yes?Chief Blur Buster wrote:]I'm told later in 2014.
Also, what can we expect from new models? Dedicated strobe (like in FG2421 - no washed our colors, correct?) instead of lightboost?
Not that specifically. Alas, I'm currently only aware that some form of 27" GSYNC would come later in 2014.crun wrote:You mean G-Sync DIY board, compatible with VG278HE, is coming later this year, yes?
Unfortunately, not even I know whether it will be available as a GSYNC upgrade board.
Currently, NVIDIA has requested that sites do not talk further (than what has already been leaked already -- seen in posts quoted here) about strobing plans, until they make an announcement.Also, what can we expect from new models? Dedicated strobe (like in FG2421 - no washed our colors, correct?) instead of lightboost?
I can however say because of my existing experience playing with strobe backlight hacking in the last year -- it's a difficult engineering issue because of the brightness-versus-clarity tradeoff (shorter strobes has clearer motion), as well as the contrast-versus-ghosting tradeoff (higher contrast ratios often create more overdrive and ghosting artifacts). Some people's opinion of better image quality is a brighter picture, and a different person's opinion of a better picture is a better contrast ratio (blacker blacks).
Hmmm... then maybe I will simply stick to my R9 290 (was trying to sell it at premium because it unlocked, would have nearly enough money for GTX 780), buy the VG278HE and delay my G-Sync probably for a year or two.
I suppose you can't really say if XL2720Z is worth waiting for?
Do you have any idea if ToastyX works with the R9 290 series?
Thank you for your quality posts. Always a pleasure to read (whether here, on OCN, H or 120hz.net)
I have no specific request from BENQ telling me I can't say.crun wrote:I suppose you can't really say if XL2720Z is worth waiting for?
The Blur Reduction on the XL2720Z is quite a lot easier to turn ON/OFF than LightBoost, and works at any refresh rate (75Hz through 144Hz). You just press the button on the included BENQ controller to enable/disable the strobing, no hacks. Works in dependently of what's connected (anything that outputs at 75Hz-144Hz works -- whether Radeon, GeForce, Intel, etc). No special drivers, no software, no ToastyX needed -- it's a hardware button.
That said, I'm keeping a lot of the good stuff for the XL2720Z review, after I install the XL2720Z firmware upgrade -- since I want to properly review the display (It's currently enroute to me).
Yes, it does.crun wrote:Do you have any idea if ToastyX works with the R9 290 series?
You're welcome! And thanks for the compliment.crun wrote:Thank you for your quality posts. Always a pleasure to read (whether here, on OCN, H or 120hz.net)
Thank you for your answer. I am perfectly fine with manually changing refresh rate etc via software though
I am going kind of offtopic, but could you say how VG278HE display compares to VG248QE, XL2720Z or XL2720T? I mean colors with and without lightboost, motion artifacts, BLB etc.
It is quite similiar in many ways to the XL2720T series in strobe mode, in terms of brightness and checkerboard artifact. BLB and colors are very similar. It's almost the same 27" panel, if not the same. What's different with XL2720Z is that the strobing is much easier to enable, colors are fully adjustable via OSD, and it doesn't have the gamma bleaching effect that LightBoost has. It will still be darker, just like turning on strobe mode on almost any monitor.crun wrote:I am going kind of offtopic, but could you say how VG278HE display compares to VG248QE, XL2720Z or XL2720T? I mean colors with and without lightboost, motion artifacts, BLB etc.
The VG278HE and the XL2720T has better color in strobing mode than the VG248QE.
