Blur Busters Forums
BenQ RL2455 Console Gaming Monitor
The XBOX ONE Console supports 120Hz+, FreeSync, and 1440p. Getting help with getting "Better Than 60Hz" on the XBOX ONE.
Re: BenQ RL2455 Console Gaming Monitor
Postby richdot » 02 Jun 2018, 04:17
RealNC wrote:
richdot wrote:So with AMA OFF it still should be more than responsive and have good input lag?
There's no input lag issue with AMA off. And I don't know what "more than responsive" means. With AMA off, you get worse pixel response, meaning more motion blur, especially at 60Hz.
I don't know what else to tell you.
Ok no problem it must be pixel reponse I mean then sorry. I have read countless threads and asked enough questions to be honest starting to drive myself crazy and everyone else lol. I think I will just keep the RL2455 from what I have read every overdrive system from each manufacturer could still leave blur or trailing or ghosting at 60Hz so might as well just stay put.
120hz on xbox is a great feature but I can't see many games supporting this they can't even hit 60fps most of them.
Thanks for the replies. great site. good info
richdot
Postby richdot » 06 Jun 2018, 04:04
Solved. update for those that run into same problems :
Returned the BenQ RL2455 and bought a ASUS VG245. What a difference I have no problems with ghosting or blur. Set freesync on just so smooth gameplay. Left it on Tracefree 60 no issues.
Thanks for the help
richdot
Previous
Return to XBOX ONE Console
Who is online
Users browsing this forum: No registered users and 0 guests
