Blur Busters Forums
BenQ ZOWIE XL2536 vs ZOWIE XL2540 240Hz
Postby Maorzz » 11 Jun 2018, 03:17
Blur reduction wise which is better where the blur will be non existent?
Maorzz
Re: BenQ ZOWIE XL2536 vs ZOWIE XL2540 240Hz
Postby Falkentyne » 11 Jun 2018, 12:37
I don't think this is the comparison you are looking for. The XL2536 is a 144hz monitor with DyAc. You probably want to compare the XL2540 and XL2546 instead, rather than comparing a 144hz and 240hz monitor, since obviously the 240hz monitor will have better blur reduction just by the higher refresh rate it can be used at!
The difference between the XL2540 and the XL2546 is that the XL2540 supports Adaptive Sync (Freesync) and the XL2546 does NOT.
The XL2540 has Benq Blur Reduction disabled (normal users can't enable it; it must be forced on in the service menu, but that's easy to do). The XL2546 has DyAC (which is Benq Blur Reduction, renamed for marketing purposes) enabled by default, which can be forced off in the service menu as well. It is unknown whether Freesync (Adaptive Sync) will work on the XL2546 when you forcibly disable DyAc (as blur reduction and freesync can not be used at the same time; trying to enable blur reduction on the XL2540 will stop freesync from working).
No one knows yet afaik, if blur reduction would look better on the XL2546 vs XL2540.
Falkentyne
Postby Chief Blur Buster » 11 Jun 2018, 21:49
Falkentyne wrote:No one knows yet afaik, if blur reduction would look better on the XL2546 vs XL2540.
XL2546. DyAc is brighter.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
Postby Q83Ia7ta » 12 Jun 2018, 04:39
Is quality of blur redution at XL2546 better too?
Q83Ia7ta
Postby Chief Blur Buster » 12 Jun 2018, 12:33
Unsure but reportedly roughly similar at the same strobe length/phase setting.
The DyAc models uses voltage-boosting to flash brighter. It is over 300 nits in strobed mode -- about 4x brighter than the average 2013-era LightBoost monitor. Most LightBoost monitors couldn't break 100 nits.
That's why if you want a brighter strobe, DyAc is good.
That said, 240Hz GSYNC monitors also flash roughly as bright -- 280 to 310 nits for the XB252Q tested in Jorim's G-SYNC 101 tests.
Postby Falkentyne » 12 Jun 2018, 16:40
Chief, man......Chief....
Please contact Benq to add 60hz single strobing !!
I'll love you long time. I PROMISE.
This can EASILY be done in the firmware. It isnt hard to do.
one strobe every 16.7ms.... how hard can that be.......
They can add it in:
XL2540, XL2547 and the new XL2740 (that new 27" 240hz panel).
Seriously Chief do you know how dim my XL2720Z is now? .......
Falkentyne
Return to BENQ/Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
Who is online
Users browsing this forum: No registered users and 5 guests
