No. It adds 1 frame of input lag. Triple buffer vsync is only useful in cases when the game's FPS falls below the refresh rate which can result in FPS halving and heavy stutter. Triple buffer vsync avoids that FPS halving and extreme stutter, but at the cost of a constant 1 frame of additional input lag.Salaverry wrote:is it advisable to have the triple buffer on?
It has lower input lag than vsync. It also has micro-stutter, but if you're fine with that, then it's a good solution to get rid of tearing. With fast sync, the higher your FPS, the less microstutter there is. In fact, fast sync at 500FPS or higher is virtually as good as g-sync, but as you can imagine, 500FPS is very difficult to reach in modern games.What are your thoughts on fast sync? I read somewhere else that with the double fps of your refresh rate would be pretty good too, but i want to hear your thoughts since you have so much knowledge.
There's a video with fast sync tests here:
https://www.youtube.com/watch?v=L07t_mY2LEU
Actually, fast sync works better with low refresh rate monitors. For example, 60Hz monitors will work better with fast sync because you get better smoothness at FPS = 3 * Hz. So it's pretty smooth at 180FPS already on a 60Hz monitor, and at 240FPS it's very smooth. With a 144Hz monitor, you'd need 432FPS to get smooth motion. With a 240Hz monitor, you'd need 720FPS...BTW, and this may be personal opinion.. but is it advisable changing my monitor to a 240hz one to avoid any troubles?
If you're going to get a new monitor and you want smoothness, g-sync is the way to go. In fact, in order for fast sync to be as good as g-sync, you need 500FPS or more, while with g-sync you get the same smoothness and with low input lag at 140FPS already.
I generally don't recommend 240Hz monitors right now, because they appear to be too problematic for my taste. They seem to sacrifice image quality in exchange for 240Hz, which I'm not a fan of. They're also quite expensive for what they are; they only cost so much because they're very niche products, not because they're that good (they're just TN panels.) But if that doesn't matter to you, then a 240Hz g-sync monitor would allow you to run a 237FPS cap with g-sync active.
