Artifacts Benq XL2735
diodema
Post by diodema » 05 Nov 2018, 04:23
Hello
I have a problem with my monitor Benq XL2735 (see attached photo): the colors of the leaves are not aligned.
What is it?
thank you
copia ridotta.png (240.24 KiB) Viewed 5150 times
Re: Artifacts Benq XL2735
Post by RealNC » 05 Nov 2018, 11:19
Does it also show if you take a screenshot?
diodema
Post by diodema » 05 Nov 2018, 11:50
Yes
Post by RealNC » 05 Nov 2018, 13:07
diodema wrote:Yes
Then it's not the monitor. It's the game. What game is it? It looks like an extremely overblown chromatic aberration effect (I hate that effect myself and always disable it if it's an option, or a tweak in the game's ini files.)
diodema
Post by diodema » 05 Nov 2018, 16:50
RealNC wrote:
diodema wrote:Yes
You are my hero: It's the game.
Thank you so much :D :D :D :D
Post by Chief Blur Buster » 05 Nov 2018, 23:14
Yes, these are GPU effects. You may need to surf through the game menus and turn off "Chromatic Aberration" or "Lens Flare" or "Lens Effects" or any similar sounding option.
Falkentyne
Post by Falkentyne » 06 Nov 2018, 12:03
Chief Blur Buster wrote:Yes, these are GPU effects. You may need to surf through the game menus and turn off "Chromatic Aberration" or "Lens Flare" or "Lens Effects" or any similar sounding option.
Sorry to bother you, Chief, but please check your PM if you have time.
