CFG70 flicker
Yuin
CFG70 flicker
Post by Yuin » 12 Dec 2018, 01:12
first post here.
my monitor cfg70 show so little flicker or not flicker at all on 120hz setting
but show normal flicker on 100hz and 144hz.
https://youtu.be/TLhTsqIsXzs
actually this is a good thing because i can gaming longer on 120hz without eyestrain.
i think this is a positive bug because i active ulmb (fastest setting) with
flicker free.
how can this is possible?? why it only trigger on 120hz??
can i trigger it on 100hz?? because nvidia 1060 gpu is not that strong.
Re: CFG70 flicker
Post by RealNC » 12 Dec 2018, 02:39
You need to judge with your eyes, not with a camera. A camera captures video at 30 or 60FPS, which means 120Hz flicker is not as visible in the video.
In reality, 144Hz has the least amount of flicker, 120Hz has a bit more, and 100Hz has even more.
Yuin
Re: CFG70 flicker
Post by Yuin » 12 Dec 2018, 05:30
This mean i got a normal monitor not
Faulty monitor.
Thanks for answer
Re: CFG70 flicker
Post by RealNC » 12 Dec 2018, 06:32
Yes, your monitor is fine.
