csgo nvidia v-sync
Abiak
csgo nvidia v-sync
Post by Abiak » 25 Dec 2018, 14:46
I used to play csgo with g-sync + v-sync + fps cap 141.
Recently I changed motherboard and meanwhile they updated the game, now nvidia v-sync is making me lag, stutter or freezing for 1-2 seconds, this happens a couple of times per game.
Re: csgo nvidia v-sync
Post by Chief Blur Buster » 25 Dec 2018, 16:54
Moving this thread to the Input Lag Forum, as there may be more replies there.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
Post by RealNC » 26 Dec 2018, 16:25
Does it still happen if you disable g-sync?
Abiak
Post by Abiak » 26 Dec 2018, 18:02
Yes, today it has not happened many times, something like 8 times in 6 games.
Sometimes when I die I think there is that "hitching" you told me about.
Also sometimes when I kill someone or when I die sound becomes very low for 1-2 seconds, I did not remember something like that.
Post by RealNC » 26 Dec 2018, 18:06
Well, if it happens even without g-sync, then it seems the new csgo update is to blame.
Abiak
Post by Abiak » 30 Dec 2018, 15:54
I think I fixed the lag, it was the autoexec file... however I still have the sound issue, basically sometimes I kill someone -> a music starts for a second -> in that second the shooting sound almost disappears, this happens 1-2 times per game. I tried to ask on Steam if this is "normal" but nobody answers...
Post by Chief Blur Buster » 30 Dec 2018, 17:03
The autoexec config file for a specific game you mean?
Diagnosing a glitch can sometimes be touch, sometimes you need to literally write 10 pages plus screenshots before a solution is achieved. Obscure problems are hard to troubleshoot in just a few sentences -- it's just the nature of the game (pun intended) -- and it's doubly challenging if writing is difficult (typing, explaining, English not first language, or other reason).
Glad your problem is (mostly) fixed!
Abiak
Post by Abiak » 30 Dec 2018, 19:23
Yes, usually people in CSGO create the autoexec file so they can check damage and tickrate.
Like I said in the other threads my PC has some issues (nvidia drivers with Firefox and white icons, virtual surround delayed etc.), however I analyzed it and should have no issues:
-Windows Disk Error Checking = no errors for both SSD and HDD
-Samsung Magician = disk conditions good
-Crystal Disk INFO = disks conditions good
-Intel Processor Diagnostic Tool = no errors
-IntelBurnTest = stable system
-MemTest86 = no errors
-Windows memory diagnostics = no errors
-CMD sfc /scannow = no violation
-Antivirus = no issue
-GPU benchmark is fine
-Steam game's cache = verified
-Steam download's cache = I cleaned it
-Windows cleanmgr = I cleaned it
-Defrag = done
-Drivers, firmware and bios are updated.
Post by Chief Blur Buster » 30 Dec 2018, 21:26
Speculating....Not sure if CS:GO issue or audio issue.
Possible issues:
- Audio driver or equipment problems (if sound is glitchy in other games too)
- Bug in new CS:GO update (if others are having similar issues with same audio)
To figure out if it is a CS:GO update related issue, try testing:
- Test a different audio device (e.g. try USB audio device, or try HDMI audio using NVIDIA/AMD drivers).
Often, many computers have a 2nd audio output device that uses different audio drivers; many GPU drivers include built-in audio drivers because of the need for HDMI audio support (e.g. piping sound over HDMI to a HDTV). This can be useful for bypassing a problematic motherboard audio driver.
Abiak
Post by Abiak » 31 Dec 2018, 11:12
I tried with speakers and jack headphones, onboard audio, monitor's audio, usb headphones: same issue.
I found some old threads which claim to have the same issue and I thought "ok, it must be the game" but then I started to have sound issues in other games too.
