TIP: Good Overdrive Settings for BenQ/Zowie XL2546
SilentMarket
Re: TIP: Good Overdrive Settings for BenQ/Zowie XL2546
Post by SilentMarket » 12 Oct 2017, 00:10
eZen wrote:
How do you get a factory reset anyway? I just want to go back to default settings.
Menu > System > Reset All.
So is that actually a factory reset? I think it is just a user reset. Some monitor has a factory reset in the service menu or factory menu.
It reset default refresh rate to 60Hz and all other things. But in the normal menu "reset all" doesn't roll back to 60Hz refresh rate like the first time I plug the monitor into the computer. And the strobe light settings doesn't seem to reset.
And after I used strobe unity, the strobe crosstalk got worse and I still don't know to get back to original strobe settings of this monitor. At first, I didn't install the strobe unity, the monitor itself has a very good strobe light that just has slightly even doubled images on all screen. Now I have triple images on the top and the end of the monitor and double image in the middle.
I read in the forum some XL2546 has triple images on the top and the end, but I didn't experience it until I installed strobe unity. Is it possible that strobe unity will quietly change monitor strobe settings if it is previously installed on the computers?
MagneticDev
Post by MagneticDev » 16 May 2018, 06:51
Hi,
First post ;)
There is a way to save the settings in the factory menu?
alejans
Post by alejans » 07 Jan 2019, 10:16
bump how do you save the setting? i got the 2546
ims2bojio
Post by ims2bojio » 07 Jan 2019, 12:15
Busterino wrote:Hello,
don't know if somebody has already posted this, but I'd like to share the settings I've found for the benq xl2456.
Following this thread viewtopic.php?f=2&t=2467, entering the factory menu, "OD" -> "OD GAIN" the hexadimal value "3F" is the value which gives the most clear image while using 240 Hz, dyac set to "off" and AMA to "Premium". The binary value is "0011 1111" and decimal "63".
Testing this http://www.testufo.com/#test=ghosting, "1080 pixel per second", I see no ghosting anymore (upper ufo), just a barely noticeable tail following the ufo at the top left corner (middle) and the same for the bottom ufo.
It's still not the same visual clarity as with dyac set to "Premium/High" but way way way better than with the "OD GAIN" set to the standard "4C". Pretty impressive :o
Now, during movement, absolutely everything looks incredible sharp.
why my od gain value are numbers not 3F or something
Falkentyne
Post by Falkentyne » 07 Jan 2019, 13:20
If I wind up buying a Benq XL2740, I'll be able to help you guys. Until then...
saw141
Post by saw141 » 14 Jan 2019, 23:29
Can you please post a picture of https://testufo.com/crosstalk with these settings and perhaps the default settings as a comparison? Also, anyone with a XL2740, please try this and do the same...I beg you.
PsYoNiC
Post by PsYoNiC » 09 Jun 2019, 22:22
can someone explain why i cant get to the factory menu ?
Post by Chief Blur Buster » 11 Jun 2019, 18:47
PsYoNiC wrote:can someone explain why i cant get to the factory menu ?
For factory menu instructions, please use this thread instead. Thank you :)
pox02
Post by pox02 » 05 Dec 2020, 13:53
sorry for jump this topic but someone know if 3F overdrive trick work on xl2546k ? i dont know how to access service menu in xl2546k to
Faustiris
Post by Faustiris » 04 Feb 2022, 08:34
Hello, do you still have this benq monitor xl 2546?
The post is old but I need your help pls :S
