I would assume this is problem of 6bit TN and/or it's AFRC algorithm. 8bit panels should not have this problem.MonarchX wrote:I have VG248QE but it cannot produce neutral grays in this test - http://www.lagom.nl/lcd-test/gradient.php . The dark gray portion of the gradient are purple regardless of calibration settings... I can't stand it... I assume other LightBoost monitors that use the same panel have the same issue.
Eizo Foris FG2421 - Where was yours made? Are you happy?
Re: Eizo Foris FG2421 - Where was yours made? Are you happy?
i7 3770
16 GB RAM
GTX 670 2GB
ROG SWIFT PG278Q
16 GB RAM
GTX 670 2GB
ROG SWIFT PG278Q
Yes, so that's why if you can spend more money -- there are superior options.MonarchX wrote:I have VG248QE but it cannot produce neutral grays in this test - http://www.lagom.nl/lcd-test/gradient.php . The dark gray portion of the gradient are purple regardless of calibration settings... I can't stand it... I assume other LightBoost monitors that use the same panel have the same issue.
Even the VG248QE with GSYNC upgrade is a lot better, and above that, is even better options. For example, some of the 27" LightBoost monitors, the fixed V2 BENQ Z-Series, or the EIZO FG2421. LightBoost was unofficial, and the colors are really bad on some models, especially VG248QE which had the worst LightBoost colors (but is popular anyway because it is cheap: Under $300). Manufacturers finally made "LightBoost 2D" official with the introduction of ULMB, Turbo240, and BENQ Blur Reduction.
