Yamakasi Catleap overclock on linux (RX580 amdgpu)
mahalel
Post by mahalel » 17 Jan 2019, 14:46
Hello everyone, I have searched your forums (which are a great resource by the way) but I can't see anything about this.
It's a bit of a longshot but I am running Ubuntu 18.10 on my main machine and play games on steam, really only Rocket League.
I have a Yamakasi Catleap monitor which historically I can push to about 2560x1440 @ 110hz without any artifacts.
Up until recently I had a R9 280x gpu and set a custom refresh rate of 96hz via xrandr, everything worked well and smooth and I was happy, but the frames weren't that good at 2560x1440.
I have just upgraded to a 580X 8gb AMD card and I thought it would be as easy as using the same xrandr command, but whenever I try to apply that refresh rate to DVI-D-0 I get an error of "Configure crtc 0 failed". I just can't seem to push past 60hz on this card.
I've tried various things, like setting custom EDID in xorg.conf and using a hacked EDID which is supposed to advertise 96hz as a valid refresh rate but it doesn't seem to apply at all.
I'm a bit down in the rabbit hole at the moment and 60hz just feels like dogshit to me, so I am desperately hoping there's someone else on this forum with a similar setup that can give me some advice :)
The alternative is installing Windows but I get shivers when I entertain that thought so I'd like to get this working if possible.
Re: Yamakasi Catleap overclock on linux (RX580 amdgpu)
Post by RealNC » 17 Jan 2019, 16:04
Does the video card have another DVI port? Is yes, try another one. Some video cards have two DVI ports, only one of which is actually DL-DVI.
Post by Chief Blur Buster » 17 Jan 2019, 20:52
Yes, try a different DVI port.
Also, I've seen dual-link DVI cables fail and become single-link DVI cables. Switch cables if needed.
I've also seen failed DVI ports too.
Could also be a driver issue with 580 on Linux not enabling dual-link DVI.
Unorthodox workarounds could include DisplayPort-to-DualLink DVI adaptors, or HDMI2-to-DualLink DVI. They're not always very reliable, but can bypass a GPU-side unexpected refusal of dual-link DVI for any hardware/software reason. Get a high-rated adaptor that has success reports of 1440p 120Hz.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
mahalel
Post by mahalel » 23 Jan 2019, 18:25
Hey, thanks for the replies.
Only one DVI port on the GPU unfortunately.
I have borrowed a different monitor which has an EDID advertising 2560x1440 @ 120hz
xrandr still only detects 2560x1440 @ 60hz
I think I will temporarily boot windows to see if this is purely a driver issue. I suspect the amdgpu driver is locking the clocks at a certain value.
Will report once I've made more progress, thanks for the advice so far.
SkOrPn
Post by SkOrPn » 12 Nov 2019, 21:43
mahalel wrote:Hey, thanks for the replies.
Hello, sorry for bringing this thread back to life but I wanted to ask you if you made any progress with Overclocking your Catleap on Linux. I too am running MX19 Linux (buster based) with a Yamakasi Catleap and a R9 290. I also can do as much as 120Hz on Windows, but I normally run 96Hz just in case its easier on the electronics and I find it just fine for my gaming needs.
However, this year I decided to start migrating my gaming to Linux simply because it is getting so much better recently. But I would like my 96Hz back. I have tried all the methods I can find to no avail. I keep getting artifacts, flickering etc when I go much over 75Hz and blank completely out at around 85Hz. Not sure I understand why this would be the case considering this display happily runs at 120Hz in Windows if I wanted to. I've now spent two solid days trying to get back the 96Hz.
Did you succeed getting back your Overclock?
