LG 24GM77 120Hz>144Hz
Jfe
Re: LG 24GM77 120Hz>144Hz
Post by Jfe » 28 Jan 2019, 17:25
Those tests I did and posted photos are fine for both values?
Post by Chief Blur Buster » 28 Jan 2019, 20:19
Yes. It showed that frameskipping was not the cause of your differences in feel.
A heavily frameskipping monitor can feel like erratic input lag (since the missed refresh cycles mean the old refresh cycles are displayed longer = laggier). But that's definitely not the cause of your lag.
Jfe wrote:Ad 1. First link is for 144Hz.
https://imgur.com/a/H4lIGs9
and this is for 120Hz
https://imgur.com/a/TDyMAfo
Your monitors are fine, you executed the test just fine (albiet exposures are short, they're sufficient since you did 2 tries).
Your monitors are not frameskipping.
However...
It appears your problem is mainly purely latency-related -- a strange lag difference between 120Hz and 144Hz.
Jfe
Post by Jfe » 29 Jan 2019, 11:36
Is possible that this input lag may be because of Respone Time setting? It feels better with Low setting on 144Hz instead of Middle like I was using.
Post by RealNC » 29 Jan 2019, 23:41
Jfe wrote:Is possible that this input lag may be because of Respone Time setting? It feels better with Low setting on 144Hz instead of Middle like I was using.
No, that would be the overdrive setting (pixel response time.) There can't be any real input lag difference between low and medium.
Jfe
Post by Jfe » 31 Jan 2019, 17:19
So I tried different scalling settins in NVIDIA and I keep that 144Hz is laggy and add input lag so I will stay with 120Hz. But I have question about restore to default settings in Nvidia does it work correct? I have weird feeling like now after I tested settings and used it to restore my settings I have sutters.
I read somewhere that there is need to reinstall drivers to make scaling to default mode. Is it true?
Thanks for your help.
Jfe
Post by Jfe » 08 Feb 2019, 19:25
I don't want to make another topic so I will ask here, so I called up service menu of mine LG and I found that my values are different compared to this from Display-Corner review. It's normal that they are calibrated differently?
This is how it looks for Display-Corner: Image
and this is mine: https://i.imgur.com/PWruw5G.jpg
Post by RealNC » 09 Feb 2019, 10:21
You have a newer firmware version, so they probably improved the calibration.
