BENQ XL2720Z 27" of goodness :) [Version 2 firmware is good]
cutiwan
Re: BENQ XL2720Z 27" of goodness :) [and firmware bug]
Post by cutiwan » 12 Mar 2014, 13:54
dafuck not have permissions to read pm: S
cutiwan
Post by cutiwan » 12 Mar 2014, 13:57
how many post I need to read pm?
Post by Chief Blur Buster » 12 Mar 2014, 15:53
3 posts.
Empyr3/cutiwan, sent you the software via PM -- you should be able to read once you have 3 forum posts. That said, if you can't find a way to contact me, email mark [at] blurbusters.com
cutiwan
Post by cutiwan » 12 Mar 2014, 16:23
thanks, but with 4 post will not let me read pm
LogicElite
Post by LogicElite » 12 Mar 2014, 16:32
Hi chief,
Hope you're going well. I just checked my firmware version and I have the v001-20131008. Does your strobe utility will help or I will have to wait for the firmware update to use it? If I can use it, can you send me the link by pm please.
Thanks.
Post by Chief Blur Buster » 12 Mar 2014, 16:36
cutiwan (emailed)/LogicElite (PM),
I have sent you a message with the link.
It probably won't work, so for the situation of a monitor that doesn't work with Blur Busters Strobe Utility:
"An update is forthcoming so please stay tuned for regional news on each of the BenQ sites."
Empyr3
Post by Empyr3 » 12 Mar 2014, 16:44
Thanks for the heads up, I'll check it later.
waterboy849
Post by waterboy849 » 12 Mar 2014, 20:49
i hope amazon has the newest firmware plz
waterboy849
Post by waterboy849 » 12 Mar 2014, 21:05
can i get the software btw? thanks
whilson
Post by whilson » 12 Mar 2014, 21:21
need the software! thanks :)
