Hey guys,
i got my C49HG90 some days ago and found out that the GSync Compatible Mode is somewhat broken.
In Ultimate Mode i get weird flickering, mainly in dark areas. Its better in some games and worse in others, but for me its not enjoyable in any game. It happens no matter which refresh rate is set and no matter at which point the frames are being capped.
In Standard Mode there is NO flickering, but the Monitor seems to be stuck at 144HZ (or the refresh rate set at driver level) resulting in stuttering when the FPS are capped at 140ht for example.
This seems to be a common problem with no workaround at the moment.
So i am currently looking for a way to get the lowest possible input lag without tearing, without Gsync/Freesync.
In my use scenario (simracing in assetto corsa and dirt rally) i can guarantee a perfect stable refresh rate up to 144hz without dips, but i have absolutely no ideo how to set up things correctly and im just confused which settings can give me a lowest possible lag with no tearing.
Thanks a lot!
C49HG90 best Settings without Gsync/Freesync
Re: C49HG90 best Settings without Gsync/Freesync
Displays: Acer Predator XB271HU / LG 48CX OS: Windows 10 MB: ASUS ROG Maximus X Hero CPU: i7-8700k GPU: EVGA RTX 3080 FTW3 UG RAM: 32GB G.SKILL TridentZ @3200MHz
Thanks a lot, the "low lag vsync on" method @144HZ is perfect for me and i dont feel any lag at all.jorimt wrote:Read here:
https://www.blurbusters.com/howto-low-lag-vsync-on/
Good to hear
The article is a bit outdated for the current RTSS version. For an up to date guide, see:
https://forums.guru3d.com/threads/the-t ... st-5380262
Steam • GitHub • Stack Overflow • Twitter
