Blur Busters Forums
Frametime spikes in Fortnite...
Re: Frametime spikes in Fortnite...
Postby Chief Blur Buster » 02 Mar 2019, 01:16
RTSS scanline sync (S-Sync) won't fix "frametimes bigger than a refresh cycle" spikes.
Fix that first before trying RTSS scanline sync.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
Postby GFresha » 02 Mar 2019, 01:17
jorimt wrote:First off, I can assure you that, if anything, a 240 Hz monitor will potentially make frametime spikes more obvious, not less; the higher the possible average framerate + refresh rate (especially with VRR), the more apparent the drops are when they occur.
If you want frametime spikes to be less obvious, you'd actually want to downgrade to 60Hz and/or a locked (console-style) 30 FPS, which obviously isn't desirable for any other reason.
Some things to check:
- What/how many background programs do you have running when gaming?
- Do you multi-task, record, or stream during gaming?
- Do you have the Windows Game bar or Game DVR enabled?
- Do you have fullscreen optimizations enabled or disabled globally or per exe?
- What is "Maximum pre-rendered frames" set to in the NVCP?
- Do you have the "Shader Cache" enabled or disabled in NVCP?
- In NVCP under "Configure Surround, PhysX," what "Processor" are PhysX assigned to (I've found forcing to GPU helps reduce frametime spikes in certain games [specifically The Witcher 3 in my experience], though I doubt this applies to Fortnite)
- Have you applied any CPU or GPU overclocks, and have you ensured they are stable?
- Does your CPU run with adaptive voltage settings, or does it run at max clocks/voltage at all times?
- Have you unparked your CPU cores?
- Are you using the sound device on your motherboard or a standalone sound card? And have you checked to see if "Enable audio enhancements" is checked under the "Advanced" tab for the active sound device (I've found this to sometimes cause increased CPU usage when checked)?
- Have you checked your idle DPC latency levels?
- Are you using a pagefile, and if so, on which drive and what size? If it's set to automatic, do you find it keeps growing?
- Do the frametime spikes reduce in occurrence or length with all syncing methods off?
- Do you see spikes like this (not counting Apex) in more games than just Fornite?
I could keep going, but I think you get the gist; there are a lot of possible things that can affect frametime spikes, and many could be placebo depending on the setup and or game.
Sometimes, no matter what you try, it just ends up being the game itself (either a specific patch or netcode/server issues at any given point), especially if you aren't seeing this in the other games you play regularly.
P.S. Approximately, how long was the play session for that graph you linked?
Hey mate awesome list and thank you for taking the time to come up with this. I will go down the list and check them off and see if spikes decrease at all. That session was around 10-15 mins and I got a spike every minute. Don't know if its possible if you have fortnite and msi afterburner installed if you can run a frametime graph in game for a few minutes and see if you get the same results. That would be dope but will def try your suggestions.
GFresha
Postby theangryregulator » 02 Mar 2019, 06:16
Here's a small sample of my frametimes from a solo game today:
theangryregulator
Postby jorimt » 02 Mar 2019, 11:05
GFresha wrote: Don't know if its possible if you have fortnite and msi afterburner installed if you can run a frametime graph in game for a few minutes and see if you get the same results.
I played a solo match, eliminated two, placed 4th:
Highest spike I saw was 25.9ms (others were in direct relation to framerate fluctuation; didn't have a constant 141 FPS lock). The spikes near the very end of the graph were from me exiting the game.
In-game settings were maxed, in-game FPS limiter was set to unlimited, I used RTSS for a 141 FPS cap (I usually use the in-game 120 cap, but assumed you were using RTSS, and I wanted to replicate), fullscreen optimizations were left enabled for the game exe, Game bar/DVR disabled, Game Mode enabled, and the game is installed on my 5TB HDD (Western Digital Black 7200 RPM w/128MB Cache).
I was running G-SYNC + NVCP V-SYNC "On" (full PC specs in sig), my NVCP settings were "Maximum pre-rendered frames" at "1," and "Power Management mode" at "Prefer maximum performance" for that game profile.
The only background program I had running was Afterburner/RTSS.
Display: Acer Predator XB271HU OS: Windows 10 Pro (1903) MB: ASUS ROG Maximus X Hero CPU: i7-8700k GPU: EVGA GTX 1080 Ti FTW3 RAM: 32GB G.SKILL TridentZ @3200MHz
Postby GFresha » 02 Mar 2019, 11:25
theangryregulator wrote:Here's a small sample of my frametimes from a solo game today:
Thank you so much for this man, looks like the same behavior as me, a spike about every minute or so. How high were your spikes though? 30 MS+ or lower?
GFresha
Postby theangryregulator » 02 Mar 2019, 11:42
yeah looks very similar to yours infact - 35+ ms or so each spike.
theangryregulator
Postby GFresha » 02 Mar 2019, 12:01
theangryregulator wrote:yeah looks very similar to yours infact - 35+ ms or so each spike.
My second question is what monitor you using? Were you playing 1080p/1440p? Gsync on/off? Any type of sync used? FPS cap? Happens to other games? Apex legends is butter smooth? Did you notice the stutters in game or just from the graph?
GFresha
Postby GFresha » 02 Mar 2019, 12:05
Going to try some of your settings and give it a go. I mean mostly its the same except I am using all low settings also does "processor power management" matter? From the power options in windows, I currently have it at 5% and max at 100% so that its not 24/7 overclocked. Also should I change my power plan to ultimate?/ high power? Currently set on balanced.
GFresha
Postby theangryregulator » 02 Mar 2019, 12:16
Viewsonic XG2402 with freesync on (RTX 2060) - 1080p. 138 FPS ingame via the config file. All low settings apart from view distance on Epic.
Apex is smooth apart from the odd stutters in certain parts of the map.
Hmm I don't think I notice the frame time spikes in fortnite but there are other stutters that are noticeable though similar to the one where all the other players load in.
theangryregulator
Postby theangryregulator » 02 Mar 2019, 12:20
Here's a squad run but this time with all my other game clients and browser closed. Spikes are in the 25~ ms region this time.
theangryregulator
PreviousNext
Return to G-SYNC
Who is online
Users browsing this forum: No registered users and 4 guests
