HOWTO: Using ULMB Beautifully or Competitively
Post by Chief Blur Buster » 06 Sep 2017, 18:24
Properly Using ULMB Beautifully or Competitively
Sometimes ULMB can improve or hurt performance.
It's not the right tool for all games, the key is to understand how to properly utilize blur reduction for maximum competitive advantage.
1. Fix ULMB Double Image Effects
Double image effects always happens when running at frameates at half the strobe rate.
For amazing ULMB, you need framerate == refreahrate == stroberate
30fps@60Hz CRT is double images
60fps@120Hz ULMB/LightBoost is double images
20fps@60Hz CRT is triple images
40fps@120Hz ULMB/LightBoost is triple images
Number of images = (strobe rate / frame rate)
Note: You might have some minor strobe crosstalk (much fainter 2nd image), but that is normal. However, double-images from half-framerate situations are much worse than strobe crosstalk.
Note2: If you are using a BenQ/Zowie monitor, use the Blur Busters Strobe Utility
2. Fix The Amplified Microstutter Effect of ULMB
Also, ULMB amplifies viaibility of microstutters (no motion blur to obscure microstutter). A single frame drop is blatantly visible even at 143fps@144Hz. Also, VSYNC OFF massively amplifies microstuttering/jittering in strobe modes. So please fix your mouse micro stutters (better 1000Hz mouse, better mouse pad), upgrade GPU, and lower strobe rate. 85fps@85Hz or 100fps@100Hz VSYNC ON strobing (+ low lag VSYNC ON tricks) can look visually much better than 110-130fps VSYNC OFF strobing at 120Hz.
Even mouse microstutter is very massively amplified in strobed modes (I do not believe the mouse manufacturers falsely saying 2000Hz true-report-rates are unnecessary. For ULMB, we NEED better mice that can turn left/right as smoothly as a keyboard strafe left/right. 2000Hz true report rates *is* important for framerate-stroberate-locked high-Hz ULMB motion). For now, get the best and smoothest 1000Hz mice you can get.
3. Get 100% Stutterless ULMB: stroberate = refreshrate = framerate
Perfect frame rate lock to strobe rate is the magic recipie for butter-smooth stutterless strobing.
Arcade-perfect Nintendo-perfect TestUFO-perfect CRT-like panning motions in games with ULMB requiess the triple lock of stroberate == refreahrate == framerate
Thusly; to reduce ULMB microstuttering:
  • Increase GPU if needed
  • Adjust detail, turn off AA temporarily
  • Use lower refresh rate to get the easier triple lock (framerate, refreshrate, stroberate match)
  • Use VSYNC ON
  • Use low-lag tricks for VSYNC ON (Set your RTSS framerate cap 0.01Hz below testufo.com/refreshrate benchmark)
  • Use overkill frame rates if you must use unsynchronized frame rates
Overkill Framerates can compensate for ULMB microstuttery/jittery effect, too
If you really, really do not want to do VSYNC ON (even the low-lag versions), then sufficient overkill frame rate (things like 300fps) can compensate for microstuttering during Fast Sync or VSYNC OFF for competitive ULMB gameplay. You will not get perfect motion fluidity but the more overkill you can get, the better ULMB becomes in non-locked situations.
4. Fix Poor Brightness
Old LightBoost was dim. Recent ULMB (and DyAc) monitors are much brighter, especially 144Hz ULMB on 240Hz eSports monitors. A quite decent colorful 300 nits in ULMB mode! And lower lag than 120Hz LightBoost.
If you're still stuck with very dim LightBoost, upgrade to a recent monitor with bright strobing. All the newer strobe-capable 240Hz monitors currently have very bright 144Hz strobing.
5. When to know ULMB is Right Tool for Right Job
Know when to use ULMB competitively properly.
- ULMB can improve human reaction time during tracking camoflaged moving objects in certain games (ULMB does not help in fixed gaze situations, as demonstrated by TestUFO eye tracking pattern), so ULMB helps certain games and gameplay tactics that forces eye movement, where the human reaction time improvements outweighs the slight ULMB lag.
ULMB doesn't help:
- Fixed gaze at crosshairs. You are immune to display-induced motion blur during fixed-gaze situations. ULMB only helps when your eyeballs are in motion, tracking moving objects. Many (not all) eSports CS:GO players keep a fixed gaze at crosshairs, using only peripheral vision to see enemies outside crosshairs. Mouse-turning/strafing to bring them into crosshairs, never moving eyes away from crosshairs. Absolute lag is more important than ULMB for gaze-only-at-crosshairs tactics.
ULMB can help competitively with better eye tracking for:
- High speed low altitude helicoptor flybys over camoflaged enemies
- Ball in Rocket League (especially if ball is dark/camoflaged)
- Analyzing panning scenery (e.g. full framerate super-hectic RTS)
- Fast scrolling Sonic Hedgehog style platformers
Know which gameplay tactics allow ULMB to have reaction time advantages
In these, human-react advantage of ULMB can end up outweighing strobe lag. The trick is to optimize to minimum strobe lag (maximize reaction time advantage of ULMB -- ULMB lag can be reduced down to as little 2-3ms average screen-center lag for 144Hz-240Hz strobe). And fix the ULMB jitteriness/microstutter (upgrade mouse, upgrade GPU, do appropriate tweaks, and do the triple lock where possible!) Then "arcade-CRT-clear perfect motion fluidity" can beckon to a competitive advantage.
List of Monitors Supporting ULMB
The list of all ULMB/DyAc/strobed monitors is found at Official List of Best Gaming Monitors. If you want the brightest least-lag strobing for competitive advantages, many strobe-capable 240Hz monitors often provides a decently bright ~300 nits during strobed mode with extremely little strobe-related lag. Remember, you can turn on/off ULMB very easily via monitor menus.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
Re: HOWTO: Using ULMB Beautifully or Competitively
Post by Chief Blur Buster » 06 Sep 2017, 18:35
Example of Certain Competitive Advantages of ULMB
AKA: "Why doesn't it help me in CS:GO, but it helps me more in certain different games?"
The animations at http://www.testufo.com/eyetracking and http://www.testufo.com/persistence are your friends in helping you understand display motion blur issues better. Motion blur disappears if you stop tracking eyes.
Turn off ULMB/LightBoost and look at this animation (on a regular LCD):
(you can run this in full screen mode too, if you wish)
1. Stare at the stationary UFO. You see vertical lines clearly, but stars are hard to see.
You're immune to display motion blur. ULMB won't help competitively.
Example: Always staring only at crosshairs in CS:GO or Quake type games
2. Eye-track the moving UFO. Vertical lines disappear due to motion blur, but you see stars better.
You're at mercy of display motion blur. ULMB can help competitively.
Example: Camoflaged enemies in high-speed low-altitiude helicoptor flyby. The ball in Rocket League. Scrolling platformers. Etc
3. Turn on ULMB (or view on a CRT) and eye-track the moving UFO.
Now you easily see both the vertical lines and the stars (line gaps) at the same time!
As observed, there are different competitive advantages, depending on your game eye-tracking habits & tactics. Is stars your figurative enemy? Or are the vertical lines the figurative enemy? Or both are enemies you need to see at the same time? In certain types of games, it could be both. To see both vertical lines and stars (line gaps) simultaneously, ULMB gives you that competitive advantage.
Other Considerations
Absolute minimum lag sometimes more important for fixed-gaze gameplay tactics
ULMB won't help you for gaze-only-at-crosshairs (absolute minimum lag is more important). But it can help you catch that camouflaged moving object, to the point where faster human reaction time compensates for the input lag of strobing. This animation is a clear demonstration. There are many games with tons of motion (and few screen-stationary elements, no crosshairs, etc) where ULMB/DyAc can help competitively more than usual. Some monitors, like the BenQ XL2546, have strobing (DyAc) on by default, since they've reduced strobe lag to extremely low levels.
ULMB/strobing and lag for eSports
In the past, many players used CRT gaming tactics (tracking eyes while turning in FPS shooter games). However, many modern eSports players moved away from that. For example, many adopt "gaze-at-crosshairs-only, use only peripheral-vision" to catch enemies, and flick-turn them to the crosshairs (to score) without moving eyes away from the crosshairs. This technique of fixed-gaze-only-at-crosshairs makes you practically immune to LCD motion blur. As a result, ULMB does not help. ULMB brings CRT-clarity LCDs back again, and is currently bringing back certain gameplay tactics formerly common in the CRT era. Everybody plays differently, so everybody benefits very differently from ULMB in different games. The key to understanding how to use ULMB competitively is knowing how to wield the "ULMB sword" correctly, bright and stutterless ULMB, with the right game/gameplay/tactics.
VSYNC OFF during ULMB
If you can achieve overkill frame rates (e.g. 300fps or 400fps), it can compensate quite a bit to smoothing out all the strobe-amplified microstuttering. The microstutter jumps (stutter vibration amplitude of moving objects) are halved at double frame rate -- e.g. 400fps VSYNC OFF looks much smoother than 200fps VSYNC OFF. This can be useful if you've got 240Hz strobing (e.g. BenQ XL2546 or LG 27GK750F) and still prefer VSYNC OFF. Things will always look smoother at framerate = refreshrate = stroberate. However, if you have overkill frame rates, VSYNC OFF may no longer have the strobe-amplified jitteriness.
The Right Tool for the Right Job: You can easily turn ULMB ON/OFF
Even with the strobe lag penalty, strobing can be a suitable competitive advantage if used properly for the right game & specific gameplay tactics. You should use ULMB to reduce human lag (in a way that exceeds the very, very tiny ULMB-technology lag on newer ULMB monitors). All ULMB monitors lets you turn ULMB ON/OFF.
It's a great competitive tool to have in a toolbox, once you know how to use the tool correctly: Using it for specific games that demand gameplay tactics that ULMB benefits. Situations where human reaction time savings consistently exceed the tiny strobe lag. And knowing how to get the game to co-operate well with ULMB/strobing.
Post by Chief Blur Buster » 18 Sep 2018, 13:42
Fixing Amplified Microstuttering Visibility From Blur Reduction
Blur reduction modes remove motion blur that normally hides lots of tiny microstutters. So turning on ULMB/DyAc/etc can amplify visibility of microstutter. You must compensate by making everything as super-smooth at everything else. Microstutters can also reduce the benefits of blur reduction, because all that shakiness/jittering re-blurs things again slightly.
Now with blur reduction (ULMB/DyAc/ELMB/etc) you have to compensate for all those jitteriness/tiny microstutters normally hidden by regular display motion blur.
First, fix your mouse microstutters
http://www.blurbusters.com/mouse-guide
.........Set Middle speed setting in "Set a pointer speed" in Control Panel
.........Set Reasonably high DPI in Mouse Vendor Software
.........Set Low Sensitivity in Game Menus
- You want mouse turn left/right to be as smooth as keyboard strafe left/right. If it's not, then fix your mouse microstutters first
- Improved mouse. Get a good eSports league mouse, set to 1000Hz
- Improve mousepad. Get an eSports league mousepad
- Clean mouse feet. Dirty mouse feet makes mouseturns much rougher
- You MUST keep Control Panel "Set a pointer speed" in exact middle notch.
- Set reasonably high DPI like 1600, highest native DPI your sensor remains accurate (and non-floaty) at. Don't use max setting which is often interpolated, but the setting about one or two notches below max. If your mouse is one of the newest sensors capable of 12800dpi, try testing 3200dpi if your game's sensitivity settings can be set ultralow enough to compensate.
- Your mouse pointer may be fast in Windows, but it will be smoother in games and ULMB benefits become more visible. You can use mouse profile software (e.g. increase DPI automatically only when the game launches)
- Install your mouse vendor software. This will ease things; many vendor software can automatically switch DPI everytime it detects launching configured executables (game executables or steam.exe etc)
If you raise DPI outside of the game, decrease in-game sensitivity (and vice versa). Strobing fluidity sometimes work work better with higher-DPI + low in-game sensitivity -- if you've got a very, very accurate high DPI mouse that stays accurate at high DPI with no acceleration. But this varies a lot between mouse to mouse, on how smooth they feel at low versus high DPI. Competitive players have their ardent favourite sensitivity ratio between DPI sensitivity and game sensitivity (These two are often adjusted in opposite directions to compensate for each other). Different players have settings different from each other. Your mileage will vary. But generally strobing fluidity tends to work better with accurate-high-DPI mice selection + usage of reasonably high DPI (set about 50% of max; since max is usually too inaccurate) + lowered in-game sensitivity to compensate for high DPI. For example, if your mouse is 6400dpi, try a 3200dpi setting (50% of max). Experiment with different ratios like 25% of max, 40% of max, and 50% of max, to see how fluidity changes during strobed turn left/right. Use mouse profiles so you have low DPI in Windows and high DPI in game, otherwise your mouse pointer is like a rocket in Windows when optimized for smooth strobed turns with low ingame mouse sensitivity settings
Next, fix your framerate microstutters
- If you play competitive at low lag, then overkill framerates far beyond refresh rate (e.g. 300fps+) can compensate a lot for microstuttering.
- Choosing a monitor with a higher-Hz ultra-low-lag strobe tech (e.g. some strobe tech has less lag, such as BenQ's XL2546 DyAc at 240Hz) can also help you achieve smoother strobing during VSYNC OFF at high frame rates.
- Alternatively, VSYNC ON does miracles in removing strobe microstutters if you don't mind a bit of lag.
As mentioned earlier, there are some low-lag VSYNC ON tricks available to compensate in part (there are multiple methods). Many people enjoy ULMB+VSYNC ON for solo gaming for ultra-smooth scrolling that is perfectly as smooth and sharp as TestUFO. In fact, some people reduce refresh rate slightly for graphics-heavy game to achieve the perfect framerate-refreshrate match, if perfect stutter-free motion clarity is a bigger priority -- because 100fps@100Hz ULMB is much smoother than 100fps@120Hz ULMB. However, this is not ideal for highly competitive ultra-high-framerate games.
Bishi
Post by Bishi » 31 Mar 2019, 04:57
Thanks for another great post, this does a great job of summarising in one place what you have written in countless others
Post by Chief Blur Buster » 04 Apr 2019, 15:19
Bishi wrote:Thanks for another great post, this does a great job of summarising in one place what you have written in countless others
You are very welcome!
Some of these will become future Blur Busters articles, too.
Krispy
Post by Krispy » 23 May 2019, 15:16
I have a ASUS ROG Swift PG258Q, I really just feel like I can not track enemies in Fortnite while looking around fast in close range encounters / editing my builds and so on. I want to try ULMB, the ROG Swift is a 240 Hz monitor with G-Sync & ULMB. I tried the following:
G-Sync On
V-Sync On (Not in game)
Capping in game files @ 237.00 FPS
Also tried:
G-Sync Off
V-Sync Off
Capping in game files @ 237.00 FPS & Uncapped FPS
I really don't know why I feel like I can not see clearly in game, my build is capable of high FPS in game I can get from 400-600.
Should I be using 240 Hz + ULMB? (Capped at 237.00?)
I don't recall exactly but I think I heard ULMB is only up to 144 Hz, so should I be capping there or capping at 141?
Any input is greatly appreciated!
Post by Chief Blur Buster » 23 May 2019, 16:30
The common advice of "Cap your framerate 3fps below" is ONLY for variable refresh rate (GSYNC, FreeSync). It's good VRR-only advice. People make a mistake assuming "3fps below" is for GSYNC-OFF or FreeSync-OFF situations. It's not for non-VRR situations.
For smoothest ULMB, you may want to use framerates matching refreshrate using either:
(A) VSYNC ON
...latency will be high though
(B) RTSS Scanline Sync
...latency will be low but will look awful whenever framerate fall below Hz
(C) Fast Sync + in-game framerate cap matching refreshrate
....latency lower than option A, but slightly higher than B, while being much easier to configure and much more forgiving
When using ULMB, don't forget to raise your mouse DPI higher, while lowering your in-game sensitivity. And use a really smooth and precise gaming mouse with clean mouse feet on a clean mouse pad.
Now, for close-range combat, your problem is possibly not ULMB, but possibly a viewing distance that is too close to monitor. Try testing increasing viewing distance slightly.
kronosX
Post by kronosX » 20 Apr 2020, 15:34
I have an Alienware AW2518H Monitor and I want to set up it's ULMB @ 144hz function perfectly for maximum competitiveness. I have a couple of questions. First of all, should I enable ULMB in NVCP or just on the monitor? Secondly, what does the ULMB Pulse Width setting do? Additionally, I am completely puzzled as to how I should use the Scanline Sync feature in RTSS to achieve the lowest latency while using ULMB.
