sharing my little secret for aw2518hf owners
pox02
Post by pox02 » 16 May 2019, 11:21
i was testing xg258q and aw2518hf both gsync/scanline sync and this is my thoughts
xg258q/gsync/od=3 236 fps overwatch smooth/little stutter
xg258q/freesync/od3= 236 fps overwatch smooth
xg258q/scanline/od=3 239 fps overwatch much smoother
since i use CRU on aw2518hf and not xg258q i cant test it cause maybe it will ruin the xg258q
now aw2518hf
aw2518hf/gsync/fast 236 fps overwatch extreme smoother
aw2518hf/freesync/fast 236 fps overwatch amazing smoother
now the real Secert
aw2518hf/scanline/CRU/fast 239 fps overwatch extreme smoother
i don't care if its higher input lag then xg258q the feeling of this overdrive monitor is amazing
settings
Image make sure you using 239.760 cause if not the scanline will not work
Rivatuner
[Framerate]
Limit=0
LimitDenominator=1
LimitTime=0
SyncDisplay=0
SyncFlush=1
SyncHotkeys=1
SyncScanline0=-180
SyncScanline1=0
SyncTimeout=1
SyncPeriods=0
enjoy the amazing gaming you ever dream on
monitors xg258q aw2518hf 27GK750F-B pg248q xg240r lg w2363d-pf xb270hu
Notty_PT
Re: sharing my little secret for aw2518hf owners
Post by Notty_PT » 16 May 2019, 11:26
I don´t like to use LCD Reduced settings with Nvidia GPU because my GPU stops idling (rocking 1300mhz even without doing anything). Also altho the overdrive artifacts were completly gone at those settings on my AW2518HF, the ghosting/blur was evident, but I didn´t use FreeSync/Gsync as it adds noticeable input lag.
However if it works for you, go ahead! We all different.
Post by RealNC » 16 May 2019, 17:16
G-Sync with RTSS frame limiter should have the same smoothness as scanline sync, because scanline sync is just the RTSS frame limiter timed to the monitor. So smoothness should be the same in both cases.
Post by Chief Blur Buster » 16 May 2019, 18:07
Theoretically.
Unfortunately, some VRR moniors/drivers duplicate a game's erratic frametimes a little imperfectly, so fixed-Hz can be a brute band-aid for that situation. Most of the time VRR outperforms. But.... I've seen S-SYNC occasionally be preferred over VRR when a game can sustain max-Hz framerates well.
Most of the time VRR is superior for stutter-free but S-SYNC has its use cases when there's extreme performance headroom where framerate=Hz don't use 100% CPU/GPU. Basically, if your computer can do perfect fluidity with VSYNC ON with virtually no framedrops, then S-SYNC becomes a viable option (As a low lag VSYNC ON lookalike technique). Framerate slowdowns can look worse with S-SYNC than VSYNC ON, but flat-out framerate can look superior in S-SYNC than VSYNC ON and )rarely) sometimes even VRR too. Fixed-Hz VSYNC ON looks great (except for lag) when you apply overkill GPU power at it, while VRR Is vastly more forgiving than S-SYNC and VSYNC ON. But the venn diagram has some small edge cases where one of the sync tech outperforms.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
theangryregulator
Post by theangryregulator » 17 May 2019, 07:20
pox02 wrote:i was testing xg258q and aw2518hf both gsync/scanline sync and this is my thoughts
Pox why have you listed gsync and freesync for the XG258Q?
Post by Chief Blur Buster » 17 May 2019, 14:59
NVIDIA calls the FreeSync compatibility the "G-SYNC Compatible" mode.
It can be a bit confusing, obviously.
theangryregulator
Post by theangryregulator » 17 May 2019, 15:22
The way he has listed it makes it look like he's testing it under two separate conditions - like maybe with a nvidia and then amd gpu unless I'm missing something.
pox02
Post by pox02 » 17 May 2019, 23:22
theangryregulator wrote:The way he has listed it makes it look like he's testing it under two separate conditions - like maybe with a nvidia and then amd gpu unless I'm missing something.
its was testing with rtx 2080 ti and vega vii
1000WATT
Post by 1000WATT » 18 May 2019, 09:27
Notty_PT wrote:I don´t like to use LCD Reduced settings with Nvidia GPU because my GPU stops idling (rocking 1300mhz even without doing anything). Also altho the overdrive artifacts were completly gone at those settings on my AW2518HF, the ghosting/blur was evident, but I didn´t use FreeSync/Gsync as it adds noticeable input lag.
at the moment I don’t have xg258q. I can’t check it myself. https://youtu.be/KTZieYrMJpA
force low.bat
nvidiaInspector.exe -forcepstate:0,8
force msi.bat
nvidiaInspector.exe -forcepstate:0,16
