Good stuff!vanden wrote:I also tested ... but for me 24 + 2*BFI @ 72Hz or 24 + 3*BFI @ 96Hz is not watchable !James Freeman wrote:I've tested with 24 + 2*BFI @ 72Hz.
Every frame of the movie was shown only 1/3 of the time (41.7/ = 13.9ms) the rest is 2 black frames.
Smoothest video experience I have ever seen, even smoother than how they project in cinemas.
I think your brain completes the missing information, resulting in an extremely smooth look even at 24fps.
Almost looks like HFR (high frame rate).
there are too flicker.
Here is an excerpt from a real movie or I see clearly the double-image effect (original 24fps) :
http://vandenk.free.fr/SVP/Home.Test-001.mkv
The same 2x faster (original 48fps)
http://e-nautia.com/vanden/disk/Publiqu ... 48fps).mkv
On my screen I see double-image effect on this 2 files ("original 24fps"/"original 48fps") ...
BFI :
96fps (original 48fps + 1 BlackFrameInsertion) :
http://e-nautia.com/vanden/disk/Publiqu ... omex2).mkv
144fps (original 48fps (Doubled) + 1 BlackFrameInsertion) :
https://e-nautia.com/vanden/disk/Publiq ... omex2).mkv
144fps (original 48fps + 2 BlackFrameInsertion) :
- On my screen "96fps (original 48fps + 1 BlackFrameInsertion)" remove completly the double-image effect ... But the brightness is divided by two and there is a little flicker (CRT).
- "144fps (original 48fps (Doubled) + 1 BlackFrameInsertion) " only 1/3 of brightness are lost and double-image effect is reduced (but visible) and there are no flicker.
- "144fps (original 48fps + 2 BlackFrameInsertion) " remove completly the double-image effect ... But the brightness is divided by 2/3 and there is a little flicker (CRT).
Note :
It's possible to completly remove the double-image effect on "original 24fps" by inserting Black Frames : 96fps (original 24fps + 2 BlackFrameInsertion @ 72Hz or original 24fps + 3 BlackFrameInsertion @ 96Hz) but flicker is unbearable !!
You can use SVP (SmoothVideo) to push the 24fps to 48fps or 60fps or even 120fps, then use black frames / LightBoost / strobing to have zero-motion-blur without double image effect, and without bad flicker. (100fps and 120fps becomes CRT-motion-style with LightBoost directly, while 50fps and 60fps becomes CRT-motion-style with LightBoost + 1 black frame insertion). It works.
Check out http://www.svp-team.com/
Interpolation is sometimes controversial, but it successfully achieves a goal of zero motion blur without flicker.
You will want to aim goal at framerate == stroberate
Then that's when you get "CRT effect" without motion blur and without the multiple-image effects.
So simply raise your framerate (via interpolation) until it stops flickering, and viola!
