What is the firmware version? What VT are you using? Tested the testufo frameskip test?aJam wrote:I got the LG, set up as advised
Congrats btw.
In my experience, turning off and back on behavior of the monitor is barely caused by incorrect Nvidia driver behavior. First - even if monitor is "blackscreening", the picture is still smooth and no stuttering (when it shows picture). Second, powercycling the monitor completely fixes blackscreeening for a time regarding how often do you open OSD (im my case it is between days and weeks of stable operation). These are clearly a monitors' firmware bugs imo, not an Nvidia driver's fault.witega wrote: Also it seems to me that the monitor no longer power cycles every 2 seconds once the driver has been correctly restarted. My monitor would exhibit behavior of turning off and back on again whenever I used the CRU "resetart.exe" application, when the settings were not enabled. But whenever I get the driver working with the CRU settings, my monitor doesn't do this power on/off behavior. This is something I will continue to track in the coming weeks.
Optimal settings are described in first post. In short, make sure you connect it via DP cable and choose "Original" scaling mode (Исходный in Russlan)buratino0611 wrote: So can anyone update the latest setting of this LG monitor for optimizing the lowest input lag plz ?
including: menu settings and the CRU
Pixel inversion artifacts (grid), are afair found on many panels that are B-grade in terms of quality. It is the exact piece of panel fault, but I'm not sure whether you can RMA it for that reason. Contact your seller. Not all units have this, as you may see by yourself, but I know no real workaround to fix it - besides make it less visible via contrast/gamma tuning.CrosShadow wrote: It's hard to get it on camera, i posted a picture but i'll try to describe it too, it looks like there's a grid when moving the camera ingame and it has the same effect on the ufo tests etc on 120 and 240p/s, it doesn't show that much in higher speeds, again switching between the 2 panels and i can definitely tell that the other panel doesn't have this issue, both have 3.08 firmware.
https://imgur.com/zo5uiMh
Ok, took for reference 2 pictures pursuiting by hand with the same settings of both screens at 120p/s of the tower, those are the results...
https://imgur.com/a/wp4QPOM Here's a better comparison about what i am talking about.
Any suggestion is welcome, i really don't want to try the luck with a 3rd screen...
