Turning off display overdrive on a laptop
pofono
Post by pofono » 05 Jul 2019, 23:18
I have a razer blade 15 and the display has overdrive turned on by default and way too high. I can see pretty bad inverse trailing when scrolling. around a dark gray webpage with white text. At 144hz, the effect is bearable (still not good), but at 60hz, it is way too much and is very distracting.
Is there a way to turn this feature off on a laptop? I don't mind a bit if ghosting if it means I don't have to deal with the inverse tails.
Thanks.
Re: Turning off display overdrive on a laptop
Post by Chief Blur Buster » 07 Jul 2019, 22:08
Razer Blade 15! Lovely gaming laptop.
Does laptop have FreeSync? Try turning that on/off. Different overdrive tuning is often done when this is turned on versus off.
pofono
Post by pofono » 08 Jul 2019, 22:43
I do not think the display have free sync. It has the BOE07AF panel.
Post by Chief Blur Buster » 08 Jul 2019, 23:55
If you want to risk screwing up display settings, one method is to download Entech Taiwan softmccs and try all undocumented DDC commands (including 0xE0 thru 0xFF) to see if there's an undocumented "Overdrive Gain" adjustment register. Remember to dump all existing values before you try modifying values, especially undocumented values. Disclaimers: No guarantees and you might modify registers that does something bad or brick your screen or void your warranty.
pofono
Post by pofono » 10 Jul 2019, 23:54
It says DCC/CI "Not supported (missing DPtx services)"
pofono
Post by pofono » 17 Jul 2019, 23:19
Is there nothing I can do then?
Post by RealNC » 19 Jul 2019, 08:35
Probably not. Unless it's the cable that doesn't allow DDC.
