Hi there SuperSlug.superslugz27 wrote:Hey Jubaz,
Is there anyway you could take some detailed pictures of what the DIY do it yourself looks like, I am very interested in making one myself.
Thanks
I think the pdf scheme is very easy to follow, anyhow here is a picture of mine,
remember this was soldered together in 20 min. So its not pretty. Your only gonna use this once.
http://goo.gl/3TvI6x
Remember to follow the pdf guide, Flash with monitor powered on into standby. (important)
On my first flash I had the monitor still connected to my main pc via DVI and powered on while flashing.
This first flash succeeded with a Green PASS, but did not flash the monitor.
On my second flash, I only connected the VGA (flash) cable to my old laptop (with LPT port) in standby mode.
And this flash worked fine.
NB. How I got out of the "Burn in mode" at the end of the flash, I am not sure of.
I think mine did when I connected my main pc via DVI again.
hope this helps you.
Regards Jubaz
