Move NVIDIA CP to the 2nd monitor, and try to create a custom resolution <144Hz, and press Test. Then you will see where the "Yes" prompt appears without your XL2411Z going out of range.akhyg wrote: i dont see any "Yes" after Test, maybe that notification goes to the primary monitor (xl2411z) and on extend i cant see it ?
how i do this (except drag from primary after where they opened)-> *Launch SoftMCCS and Nvidia onto 2nd monitor
I tried 1920x1081 and 1920x1079, nothing changed. Can't be bothered to do more testing, just hoping for the app to come out in the near future. It's pretty cool that CSGO accepts -freq/-refresh launch parameter, that way you can keep the desktop at 144Hz and only use the overclock while in CSGO.urut wrote: In my case csgo fullscreen works when i created cru resolution but with 1 pixel hiigher than its normal. I play csgo on 1280x1024 so i created in cru 1280x1025 (yes, 1025) and set it on desktop on 210hz, then launch csgo and its working, mat info showing 1280x1025 @ 210hz. Try it maybe.
