My monitor can go dark when I let the computer turn off the display (it was set to 10 minutes), but I usually turn off the monitor by hand. Only yesterday had I ever had it happen twice mid-game in counter-strike (I had a youtube video running in the bg and the audio got all Matrix distorted (when Neo got that silvery mirror thing on him and it went into his throat)). It seems to be happening way more often too and even when I'm in front of the computer. This doesn't seem to be a monitor issue per se because I can't shutdown the computer via the .lnk shortcut and its keyboard shortcut either. So it definitely freezes.
The eventvwr notifications are down below.
It happened with my 780 ti (*) and it's happening with the rx 580
I bought the rx 580 because I thought the 780 ti was broken. I was running the 780 ti on HDMI for a while but I can't recall if the issue happened because I wasn't gaming at all due to 60hz eye cancer.
Questions
I guess it's a silly question but could setting Strobe in any way damage the monitor? I didn't overclock anything. I have it off atm via the service menu and I will connect the DP cable in a day or two with it turned on.
Why does the model BNQ7F33 come up? I would have skipped this forum, simply bc I wouldn't have thought of it, but I found this via google viewtopic.php?f=13&t=4539
What would you guys tip it is? PSU, SSD?
Could the Displayport be broken? DP Cable oO ? (but with these messages?)
devmgmt.msc had Generic PnP Monitor as driver even though I could have sworn I installed xl2411p drivers. Currently it says ZOWIE XL LCD (HDMI)
My monitor is a xl2411p
Code: Select all
CPU: AMD FX-6300 (Piledriver/Vishera, OR-C0 (Orochi))
3500 MHz (17.50x200.0) @ 3000 MHz (15.00x200.0)
Motherboard: MSI 970A-G43 (MS-7693)
BIOS: V10.6, 01/08/2016
Chipset: AMD 970 (RX980) + SB920/SB950
Memory: 16384 MBytes @ 800 MHz, 11-11-11-28
- 8192 MB PC12800 DDR3 SDRAM - Kingston 9905471-030.A00LF
Graphics: ASUS DUAL RX 580 OC 4GB
AMD Radeon RX 580, 4096 MB GDDR5 SDRAM
Drive: Samsung SSD 850 EVO 250GB, 244.2 GB, Serial ATA 6Gb/s @ 6Gb/s
Drive: SAMSUNG HD204UI, 1953.5 GB, Serial ATA 3Gb/s
Sound: ATI/AMD SB800/Hudson-1 - High Definition Audio Controller
Sound: ATI/AMD Bermuda/Ellesmere - High Definition Audio Controller
Network: RealTek Semiconductor RTL8168/8111 PCI-E Gigabit Ethernet NIC
OS: Microsoft Windows 7 Ultimate (x64) Build 7601The error messages are as follows:
Code: Select all
Information 2019-07-08 21:38:32 Service Control Manager 7036 None The WinHTTP Web Proxy Auto-Discovery Service service entered the running state.
Information 2019-07-08 21:42:23 Service Control Manager 7036 None The Application Experience service entered the running state.
Information 2019-07-08 21:52:23 Service Control Manager 7036 None The Application Experience service entered the stopped state.
Information 2019-07-08 21:55:32 Display 4107 None A caller specified the SDC_FORCE_MODE_ENUMERATION flag in a call to the SetDisplayConfig() API
Information 2019-07-08 21:55:32 Service Control Manager 7036 None The Diagnostic System Host service entered the running state.
Information 2019-07-08 21:56:00 Display 4107 None A caller specified the SDC_FORCE_MODE_ENUMERATION flag in a call to the SetDisplayConfig() API
Warning 2019-07-08 21:56:01 Kernel-PnP 219 (212) The driver \Driver\monitor failed to load for the device DISPLAY\BNQ7F33\5&6ba4849&0&UID512.
Information 2019-07-08 21:56:02 Display 4107 None A caller specified the SDC_FORCE_MODE_ENUMERATION flag in a call to the SetDisplayConfig() API
Warning 2019-07-08 21:56:04 Kernel-PnP 219 (212) The driver \Driver\monitor failed to load for the device DISPLAY\BNQ7F33\5&6ba4849&0&UID512.
Warning 2019-07-08 21:56:05 Kernel-PnP 219 (212) The driver \Driver\monitor failed to load for the device DISPLAY\BNQ7F33\5&6ba4849&0&UID512.
Warning 2019-07-08 21:57:18 Kernel-PnP 219 (212) The driver \Driver\monitor failed to load for the device DISPLAY\BNQ7F33\5&6ba4849&0&UID512.
Warning 2019-07-08 21:57:24 Kernel-PnP 219 (212) The driver \Driver\monitor failed to load for the device DISPLAY\BNQ7F33\5&6ba4849&0&UID512.
Information 2019-07-08 22:07:02 Service Control Manager 7036 None The WinHTTP Web Proxy Auto-Discovery Service service entered the stopped state.
Information 2019-07-08 22:19:17 Service Control Manager 7036 None The Diagnostic System Host service entered the stopped state.
Information 2019-07-09 06:22:04 Kernel-General 12 None The operating system started at system time 2019-07-09T04:22:03.860398900Z.
here's a pastebin for slightly better readability if wrap lines (firefox) are turned off https://pastebin.com/raw/KQJNhX2Z
(*) 780 ti error messages. I think all these messages happened while I was on displayport.
All error messages have the same timestamp
Code: Select all
Error 2019-07-03 20:55:54 nvlddmkm 14 None
The description for Event ID 14 from source nvlddmkm cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
\Device\Video7
0c71(1750) 84015a93 a5a5a5ad
Warning 2019-07-03 20:56:08 Display 4101 None
Display driver nvlddmkm stopped responding and has successfully recovered.
Error 2019-07-03 20:56:15 nvlddmkm 14 None
\Device\Video7
3d6c(25b0) 00000000 00000000
The description for Event ID 13 from source nvlddmkm cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
\Device\Video7
Graphics Exception: ILLEGAL_OPCODE
\Device\Video7
Graphics Exception: ESR 0x404490=0x80000004
\Device\Video7
Graphics Exception: MISSING_MACRO_DATA
\Device\Video7
Graphics Exception: ESR 0x404490=0x80000001
\Device\Video7
\Device\Video7
\Device\Video7
\Device\Video7
\Device\Video7
\Device\Video7
\Device\Video7
\Device\Video7
\Device\Video7
\Device\Video7
\Device\Video7
\Device\Video7
\Device\Video7
\Device\Video7
\Device\Video7
\Device\Video7
\Device\Video7
0c71(1750) 00000000 00000000
posting this and going afk in hope the computer doesn't freeze again. -.-
