I get constant frame spikes with a 5-10 fps drop and intermittent input lag (which seems to change with the stutters).
Everything is set up right, there is no bloatware or anything running in the background.
It happens no syncs, vsync on, gsync on with or without vsync.
It happens even If I'm not doing anything so its not the input or mouse polling.
I can limit the fps so nothing is near maxing and it still does it.
All the usage and temps are normal, 3D Mark benchmark is fine and during that it doesn't stutter at all.
I've reset the pc and reinstalled windows about 5-6 times and it makes no difference.
Its a pre built pc and its been back twice and they said all tests are fine. Even though the 2nd time they said they replaced the gpu and a fan because I was complaining about buzzing and noises (Even though they still happen).
1070TI, i5-8400, 8GB 2400 Ram.
I feel like there is nothing else I can do, there is clearly something not right though.
Anybody help me?
Edit:
Also on BO4 there are some strange issues, but I think they are more the game because its not like all the other games.
I have it limited to 60 fps and the CPU usage spikes to 100% and causes huge stutters. Also it randomly drops the GPU usage right down and and maxes out the CPU, it literally stuttered and went to 1%GPU/100% CPU.
