Can someone tell me how what is happening on the screen is normal?
https://drive.google.com/drive/folders/ ... sp=sharing
Manufactured: March 2018
ASUS XG258Q frame skipping?
Re: ASUS XG258Q frame skipping?
does that go away when you turn on freesync / adaptive sync?
nooof_oof wrote:does that go away when you turn on freesync / adaptive sync?
After I turn on adaptive synchronization, nothing changes.
If vertical synchronization is disabled in Nvidia drivers, then there is a problem.
And if it is turned on or in auto mode, then everything is fine ..
upd2.
The monitor does not understand how many FPS is displayed on the screen. (Through the standard menu, you can display the FPS counter)
I will take on RMA
I will take on RMA
