Hi I just change monitor from Acer predator XB241H 144hz to BenQ Zowie XL2536 (DP CABLE) .
I feel that playing in the new zowie monitor make my performance worse.
Problem that I feel after 2 days with it.
- Hard to aim. Feel cannot see the opponent quickly enough as compared to my old monitor(old monitor does not use gsync)
- Mouse seems very slow all the sudden although same DPI and sens (900 dpi, 4 sens in game)
- Eyes fatigue all the time and hard to concentrate.
Not sure is it lag, input lag, display lag. Is there anything I missed? Any setting to the monitor that recommended?
My pc specs
Ryzen 7 2700 @3.9
RTX 2070 Super
16GB DDR4 3200Mhz.
Mouse:
Glorious model O , Logitech G pro Wireless.
In game settings, (this setting when playing are the same for both monitor)
-vsync off,
-triple buffer off
-reduce buff ON
-1920x1080 (144)
- high texture, others low.
- fps - custom (jumping around 160-220)
nvidia control panel setting (this setting when playing same for both monitor)
-open GL rendering : RTX 2070 super
-power : prefer max performance
-refresh : highest possible.
-low latency : off (any impact on this with dyac monitor and overwatch?)
xl2536 setting
-dyac : premium. (tested high, seems better for me, not sure)
-black equalizer : 0-2 (still adjusting)
-color vibrance 10
-AMA : high
-sharpen (6-8)
-gamma (3/4)
-instant mode on.
-brightness 0-15. (Is the brightness should be high? because when dyac to medium, it always cranks up brightness to 70).
Some question :
1. Should I reinstall GPU driver when connect new monitor?
2. Should I use the BenQ strobe utility? (if yes, any setting recommended?)
3. Any minimal brightness for the monitor?
4. Should Dyac be used for overwatch? (im both tracking and flicking person)
I would like to achieve minimum input lag, higher fps, and better quality than now if possible,
Thanks
XL2536 Dyac-Overwatch-Advice?
Return to “General — Displays, Graphics & More”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
