I want to buy a 240 Hz monitor for competitive Counter-Strike: Global Offensive.
What i think i learned so far:
I have to decide between G-SYNC or a Motion Blur Tech. The two technologies dont work together yet so i will not be able to turn on both at the same time.
My PC can render more than 300, sometimes 500 fps consistently on all competitive maps and i read that Motion Blur Tech might be the right choice in those scenarios with high framerates.
My questions for you guys are the following:
Am i right, that i want to turn on some form of Motion Blur Tech for the best viewing experience in fast moving scenes like flick shots and when i snap to angles?
Are there major differences in the technologies ULMB and DyAc? Is DyAc brighter than ULMB (more nits)?
Must i expect any added latencies when i use any of those technologies?
What would be your recommendation for "the best 240 Hz monitor for CS:GO"? BenQ ZOWIE XL2546? I think that is the one i saw being used at the current Major Starladder Tournament in Berlin.
I would love to learn in-depth about minimizing latencies and getting the best possible viewing experience so:
PLEASE TEACH ME SENSEI
Thanks in advance my fellow quality seekers.
