I did own a PG258Q but couldn’t stand the Ghosting/Blur/Blue Trail and the Input lag felt worse than my S2416DG.1000WATT wrote:Photos were taken from 1/1000 to 1/3200.Chief Blur Buster wrote: It's accurate to an error margin of approximately (camera shutter time + refresh cycle time), though there can be additional variables. So a 1/240sec shutter and a 240Hz monitor, will add about a 2/240sec error margin band to your latency result comparision. That can be good enough for some user testing if you don't have other requipment.
If the software does not fool me.
https://imgur.com/a/G1yoz3X
Do you propose to limit yourself exclusively to testufo.com at ghosting test?Q83Ia7ta wrote:The work of overdrive can be seen at testufo.com at ghosting test for example.
I'm not so conservative. and I prefer to customize each color (rgb) separately using a completely different test.
But you are right, the traditions of the forum should be respected.
x25
default
https://imgur.com/a/nW9YsMy
od 3
https://imgur.com/a/o7V8yZQ
od 4
https://imgur.com/a/X00SOyY
Aren't you interested in checking this yourself? or you replace monitors so quickly that there is no time to study them)). I recommend returning it, vertical lines (inversion) spoil everything.OwBoNo wrote: What settings do you recommend for lowest Input Lag and the least Motion Blur/Ghosting and still having good colors.
I don’t own any testing equipment so I go by asking people’s opinions, experiences, and looking up reviews. I will receive the monitor tomorrow, do you think the Acer XN253QX would have been a better choice? Oh and which 240hz do you recommend.
