About the Xl2546 Brightness with Dyac
Hi, i'm a user of XL2546,and i found that when the Dyac is On then the monitor brightness increase a lot.It is more helpfull for me to track enemy in games.But i prefer to no using Dyac.So i want to know is there have any way that i not only can keep the brightness but also set the Dyac to off?
Re: About the Xl2546 Brightness with Dyac
Something wrong with your settings or the monitor. Mine has the same brightness with DyAc enabled and disabled.
BenQ XL2546, i9-9900K @ 5.0 GHz, RTX 2080 Ti, 32GB (2 x 16GB) 3200 MHz CL14 RAM, Asrock Z390 Phantom Gaming-ITX/ac.
DyAc is a voltage-boosted strobe backlight.
In some cases, the total number of photons per second during DyAc actually exceeds the number of of photons per second during sample-and-hold.
In this case, there is no remedy. It's just the voltage-boosted strobe backlight working so well in eliminating brightness-reduction during strobing.
The DyAc versions of the BenQ ZOWIE monitors have among the brightest strobe backlight modes I have ever seen. Can sometimes exceed 300 nits strobed. None of the common darkening you see with most strobe backlights.
