radeon anti-lag+scanlinesync?
mist
Post by mist » 07 Oct 2019, 18:23
Is radeon anti-lag compatible and useful with ScanlineSync or not?
Re: radeon anti-lag+scanlinesync?
Post by RealNC » 07 Oct 2019, 23:15
It is compatible since it only affects the prerender queue size. As to how useful it is, not sure. If the GPU gets completely maxed out (which is where anti-lag helps,) you'll have bigger issues to worry about with ssync than input lag. Like severe stutter.
HiAlgoBoost
Post by HiAlgoBoost » 12 Oct 2019, 02:50
@RealNC - no, that is not correct:
1) "it only affects the prerender queue size" - not true (don't believe everything NV fans say)
2) "GPU maxed out ==> severe stutter" - also not true.
Sparky
Post by Sparky » 12 Oct 2019, 03:56
HiAlgoBoost wrote:@RealNC - no, that is not correct:
1: what else, specifically, do you think it does?
2: this is in the context of scanline sync.
HiAlgoBoost
Post by HiAlgoBoost » 17 Oct 2019, 14:37
What do you mean “what do I think it does”? I know exactly what it does... ;)
