BenQ UNIVERSAL 144Hz->220Hz OVERCLOCK for 1080p 144 Hz
hleV
Post by hleV » 14 Oct 2019, 06:30
If your OC'd refresh rate profile is created properly and can be seen by the game, setting BF4's .exe to run at "Maximum Refresh Rate" in NVIDIA CP (or AMD's version of it) should do the trick.
tharos96
Post by tharos96 » 14 Oct 2019, 06:49
hleV wrote:If your OC'd refresh rate profile is created properly and can be seen by the game, setting BF4's .exe to run at "Maximum Refresh Rate" in NVIDIA CP (or AMD's version of it) should do the trick.
NVIDIA CP is set to "highest available refresh rate" but ingame BF4 will only allow 144hz as the highest option. OORBuster running in the background.
hleV
Post by hleV » 15 Oct 2019, 01:33
Do other games run at OC'd refresh? You may need to create custom resulution via CRU in order for games to use it.
tharos96
Post by tharos96 » 15 Oct 2019, 05:50
I tried both the LCD standard timings and Chief's timings in CRU without success. Only NVIDIA CP seems to work for me :/
Here are the CRU settings I tried without success (No Signal) and the OSD message I get after some time with the pixel patcher enabled.
remka56
Post by remka56 » 15 Oct 2019, 17:02
Hello guys , does 200 hz benq xl2720z work with dvi cable ? (playing cs go).
toptweaktopnotch
Post by toptweaktopnotch » 18 Oct 2019, 06:25
hi guys,
i did overclock my 2411z to 195hz stable and i really like it a lot (only using 195hz in games, WIN10 @120hz).
Thx to all involved people that make this tweak happen ;)
i also use OORFixer.exe and it works absolutly fine. Good work!
@hleV i just saw in your description that u use 180hz on your 2411z, is there a reason and could u explain? ;)
best regards boissssss
hleV
Post by hleV » 18 Oct 2019, 09:48
toptweaktopnotch wrote:hi guys,
Anything above 180Hz is not stable for me. It might work stably for hours in one game but go white screen in another, etc.
zn1p
Post by zn1p » 30 Nov 2019, 03:51
Hi, guys
Tried the settings in nvidia cp on Xl2430. At 200hz I think I can see some kind of horizontal scanlines (the image is less solid, so to say, than at 144hz) and some shimmering. And at 210 and 220 the right side of monitor looks messed up (attached a photo), text becomes hard to read.
Am I doing something wrong? Blur reduction is turned off.
art1sta
Post by art1sta » 01 Dec 2019, 14:03
Hello!
Works for me at 240hz with XL2420z monitor!! with one screen,ATI GPU and CRU(ToastyX) with the S-Switch trick!!! :D
But i have a lot of artifacts... maybe is for my configuration?
Config @ ToastyX
Active: 1920x1080
front porch: H=88 V=4
Sync width: 44 5
back porch 148 36
Some help will be apreciated!!
hleV
Post by hleV » 02 Dec 2019, 01:33
Try lower refresh rate.
